Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. MUNCIE
    MUNCIE
    from Houston
    That hood looks good, don't feel too bad about finding the bondo.Mine was the same.It looked like it had been beat with a ball peen hammer.:eek::cool:
  2. Locoxp
    Locoxp
    Some real nice work been done on some of these old falcons on this thread! Mine is in storage for now, but when I left it had just installed the TCI front end and finished the rear set up.. not as pretty as some but you make do with what you have.. angle grinder and a welder
  3. nash510
    nash510
    from Vista, CA
  4. hotroddon
    hotroddon
    Doing a little restyling on the rear of my Convert. I had a concpet for what I wanted on the rear of this car to go with the GT350 front end I had done. Been so busy at PerTronix I didn't have time to do this. My Ex Employee now has his own shop and does great metal work, so I let Chris at Romance With Rust tackle this for me.
  5. falconizer_62
    falconizer_62
    Looks awesome to me!! Great work. :D
  6. falconizer_62
    falconizer_62
    Keep posting pics of the rear progress Hotroddon. Looks great and interesting. curious to see how it all comes out.
  7. nash510
    nash510
    from Vista, CA
  8. Evilfalcon1961
    Evilfalcon1961
    from Ma
    squire wagon I just picked up ![​IMG]
  9. zombie289
    zombie289
    from SoCal
    Looks great! Kinda reminds me of something Holman Moody mighta done!
  10. need louvers ?
    need louvers ?
    Nice wagon EvilFalcon1961! Sorry I hadn't answered your P.M. yet, but I'm not too sure I'm going to completely part my wagon quite yet. It's driveline and suspension will probably end up in my ranchero, but I'm kinda thinking of keeping the body together at the moment as I know where there is a very clean but damn near totally stripped '62 wagon shell that I might be able to pry from the owner's hands. I can't quite let that car die completely yet...
  11. Evilfalcon1961
    Evilfalcon1961
    from Ma
    completely understand ! and thank you, I love it already
  12. Bigcheese327
    Bigcheese327
    I’m not sure if I’ve mentioned it here before, but I have a build thread going on for my ‘62 Falcon Deluxe and my wife’s ‘61 Futura. I mention it because the ‘62 is sort of beginning to pick up steam.
    I’m hoping to get the engine / trans / rear axle swap on the Futura underway this winter.
  13. homealone
    homealone
    from texas
    I thought I would share my 63. Nothing special other than the T-5.
  14. Flootiebuell
    Flootiebuell
    Super sano!
    Sent from my SAMSUNG-SGH-I727 using H.A.M.B. mobile app
  15. Bigcheese327
    Bigcheese327
    Sharp. Is that T-5 backing up a 170? I like the wheels, too: V6 Mustang?
  16. falconizer_62
    falconizer_62
    Thanks for the heads up. Just subscribed! :)
  17. falconizer_62
    falconizer_62
    Very nice! And cool deal on scoring a wagon evilfalcon.
  18. falconizer_62
    falconizer_62
    I finished the hood today. Color sanded and buffed it this morning, and this afternoon the chrome shop had the boomerang done. Sweet timing.
  19. homealone
    homealone
    from texas
    Yep, the 170 is still hanging out up front. And a yes on the V6 Mustang wheels. I painted the recesses darker to give them a little more definition.
  20. mcnally351
    mcnally351
    from boston
    Awesome wagon!!! Did you pick that up in Oxford ma? On ma Craigslist
    What's the plans with it?
  21. Bull
    Bull
    What year Mustang? Got any specs on the wheels? Sizes? Backspace? Tire sizes?
  22. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Hahah yes ! The 700 dollar wagon. In the process of redoing the woodgrain and putting the trim back on . Satin clearing the patina. And lowering it 3in front and back. And running my 14 inch steal wheels with original cal custom 4 lug spider caps and drive the hell out if it !
  23. homealone
    homealone
    from texas
    2005+ Mustang.
    They are 16x7 with I believe a 39mm offset. I am running 205/60-16 tires.
  24. spuds
    spuds
    from Idaho
  25. YES! great plan Evil . Can't wait to see pics of it "Done" .
  26. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Damn, ya'll have been busy.
    I've been goofin' off mostly with the exception of one small project.
    I've been running a low pressure hydraulic brake lite switch:
    I haven't been real happy with the hydraulic switch's function in stop n' go traffic out a**** the m***es who are all busy lookin' at their phones while they should be payin' better attention to the road so I decided to cobble together a pedal mounted mechanical brake lite switch:
    I used a NAPA ECH SL200 mechanical brake lite switch and an adjustable master cylinder push rod that I bought from a Mustang vendor on the net.
    I picked up the nylon bushings for the mounting stud and the push rod from the same outfit. The mounting stud was made from a 9/16" OD leaf spring shackle pin that I shortened and drilled a hole in for the retainer.
    After the push rod was shortened a half inch and turned down for more threads, it was just a matter of crawlin' under the dash and puttin' it al together on the brake pedal:
    I used a 20A fused constant hot circuit to the switch and the output went directly to the stop lite feed on the turn signal switch.
    Now, I can "tap" the brake pedal and maybe get the attention of the idiot behind me.
  27. mcnally351
    mcnally351
    from boston
    I knew it, was eyeing that. Looks like a great start. Def post pics, dropped wagons are the ****. Where can you get the spider caps? Only nos ones floating around , or does someone make repros?
  28. gimpyshotrods
    gimpyshotrods
    I just did the mechanical brake light switch conversion, on my '60, for the same reason. The pressure switch does not come on, until you have built pressure. Now, I have lights, the instant I touch the pedal.
  29. falconizer_62
    falconizer_62
    cool deal on the brake switch! all sorts of good ideas on here :)
  30. Falcondad
    Falcondad
    from Tracy CA
    Like the brake light switch idea. Since I dot like the idea of my brake lights only working half the time on my 60.
    ROTTEN CC Tracy Ca.
