Custom 3sp column shift levers?
Discussion in 'The Hokey Ass Message Board' started by solo_909, Nov 23, 2013.
  1. solo_909
    solo_909
    Does anyone know where I can pick up a Custom 3sp column shift lever? When I'm in third the lever hits touches my leg and doesn't give me room for a comfortable ride. I know I can heat the metal up and bend it but it would be nice to not mess with the original lever.
    Thanks,
    George
  2. Jalopy Joker
    Jalopy Joker
    what kind of car? post some pics.
  3. solo_909
    solo_909
    Sorry it's a 53 mercury.
  4. Something adjusted wrong, bent, broken? It wasn't that way when it left the factory.
  5. solo_909
    solo_909
    Maybe, but it seems to shift into gears fine. The issue may be that I'm 6'7" lol.
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Too tall for car!
    My Son in-law is 6'8'', he has the same problem!
    Time for a floor shift.
    KK
  7. propwash
    propwash
    from Las Vegas
    heat it near the steering column and gently bend it up a bit. His height is the problem for sure. If a decent floorshift is not a satisfactory solution, then he'll have to learn to live with what he has.
  8. R Pope
    R Pope
    Lengthen both shift rods equal amounts, that will move all the gears "up" and give you more room.
  9. Can't you just adjust it with the levers under the hood?
  10. Longer arm coming off the column or drill holes closer in on the shift arm on the trans will make the shift pattern shorter on the column.
  11. solo_909
    solo_909
    A floor shifter sounds pretty cool. What all would I need to do that? Is there a conversion kit?
