Flaring stainless steel lines
Discussion in 'The Hokey Ass Message Board' started by mustangmike6996, Nov 17, 2013.
  1. rramjet
    rramjet
  2. rfraze
    rfraze
    Rigid brand flaring tool has worked well in my shop for years. After cutting, I use the proper size drill for inside diameter of tubing to clean up end, then the chamfer tool. Bend up some short pieces of different angles with the start line marked. Use these bend samples to mark start line on tubing to be bent. Hope this helps. Yes, it IS worth the effort.
  3. mustangmike6996
    mustangmike6996
    from the D
    I picked up the Eastwood style Single Double flaring tool. I liked the mastercool but there were many more bad reviews with the people who used stainless. Plus There is more to go wrong due to the hydraulics. I will be getting the 37 degree adapter for about 100 bucks so Ill have 300 bucks into tools.
    Im currently figuring out how much and what size AN fittings I will needs. ANplumbing dot com seems to have the largest selection. I have only done a little searching this far and I have a date with some beer at the bar sooooo Ill continue the search tomorrow lol.
  4. mustangmike6996
    mustangmike6996
    from the D
    Well... after long hours of research and price checking, I bought about 100 bucks worth of AN fittings from autoplicity. even with shipping (most companies waive it if the order is over 100 bucks) i was way cheaper.
    I will be getting the 37 degree flaring die from eastwood shortly. I am also replacing the stock distribution block and separate proportioning valve for the all in one unit so i can hide better. (plus there will be less fittings to worry about)
    What a learning experience this was.
  5. thebronc4019
    thebronc4019
    from New Jersey
    I did all of the lines in my OT car 11 years ago and never had a leak. I was meticulous about cutting the tubing with a "fine" tooth hacksaw and dressed all of the ends with #600 grit sandpaper. I did single flares to AN fittings. I know I will get a bunch of **** for this but I used a 45 degree flaring die and mated them up to the 37 degree AN fittings and NEVER had any problems at all.
  6. mustangmike6996
    mustangmike6996
    from the D
    The flaring tool and 37 degree die is on the way. I also got a pretty good deal on the AN fittings and SSBC prop valve as well.
  7. seb fontana
    seb fontana
    from ct
    I got a SS 3/16" line kit from Jeg's...It came with SS nuts and tube was "supposed" to be 45° double flare capable..My flaring tool, traditional Snap-on, could hardly move the material...I got pretty peived and threw it back on the shelf...I did cut it with a pipe cutter and I did throughly deburr..As per suggestions I'll try again by sawing and filing but real doubtful..It does seem to bend ok..probably would polish nice too...
  8. rfraze
    rfraze
    Mustangmike, I want to hear how the tool you bought is working.
  9. langy
    langy
    Ive been useing the Rigid tool and Speedway stainless line for donkeys years now, I find it the softest line out there, the Summit line is definitly harder. I use AN single flare fittings as thats the easiest way of doing stainless lines.
    As for 45 double flares I have done that as well but you need a very good tool like the Sykes-Pickavant tool but its still tough to do. 45 degree stainless fittings are quite common in england but i've not seen them in the US.
    As for cutting i use a thin cutting wheel in my bench grinder and then just file smooth, you need to slightly deburr and chamfer the end of the holes and use a tiny bit of brake fluid as lube, this makes the job a breeze.
  10. Desert1957
    Desert1957
    from Pa/Md
    What should I use 45 or 37 degree flares
    There are many different plumbing systems available, and which one is right for your application? We are going to talk about the 3 most common: Inverted Flare, -AN and Pipe.
    Inverted Flare or 45 is on all standard automotive applications, cars and trucks from the 30's to mid 80's have inverted flare fittings at all the connections. Inverted flare is a single nut that uses a 45 degree double flare. This flare is lapped over so the tube is double thickness at the end. A inverted or double flare has a tube nut that pushes the flare against the br*** seat to make a leak proof connection. For a leak to stop the flare it must seal against the br*** seat. Using Teflon tape does no good because the thread is not what seals the line to the flare. The tape seals the thread but the fluid will still leak between the tube and the hole in the fitting. When sealing newly flared lines to old components the line must be tightened then loosened and the process must be repeated until the leak stops. If component br*** seat is used, you are trying to seat over the existing crush ring, this may take a few tries but repeating the process will form the line flare to the br*** seat. To form the end of the tube it requires a 45 degree double flare tool. Inverted flare fittings and tools are always less expensive because they are more common.
    -AN or 37 is short for army/navy standard this system was never used on new cars from the factory. The -AN system was used on military equipment and introduced into the auto aftermarket in the 60's. The -AN fittings are a two part fitting part, one is a nut and part two is a sleeve. The nut holds the sleeve and tube in place. Since -AN uses a 37 degree single flare a sleeve is required to give extra support to the flare. This single flare can leave a rough edge to the tube since it is not rolled over. Since -AN fittings were never used on factory applications a adapter fitting must be used on any factory master cylinder or proportioning valve. So instead of having one fitting into the master when using inverted flare there will now be a nut, sleeve, and adapter. The down side is that there are now three connections and the cost of three fittings. To form the end of the tube it requires a 37 degree single flare tool. -AN flare fittings and tools are generally more expensive because they are less common.
    Pipe is a tapered thread that uses the thread of the fitting to seal against the thread wall of the component. Teflon tape is used at this connection because the threads are sealing the part. All tapered fittings are pipe and require tape. Pipe fittings can also be seen on factory cars, some fuel pumps, and other components use pipe thread. Most after market parts: residual valves, adjustable valves, aftermarket calipers, thru frame fittings, and etc are made using pipe thread. Pipe thread is a universal system designed to work with all systems. Pipe thread is used to connect different systems. Pipe adapters are made for both -AN and inverted flare.
    The problem with all these systems is it's like different languages and -AN is one language, inverted flare is another language, and pipe is the translator. Pipe works with both but -AN and Inverted flare do not work together.
    If you choose to use -AN you will have a 37 degree flare and if you choose Inverted flare you will have a 45 degree double flare. The double flare is a stronger flare but more difficult to make. Both of these flares can be formed on stainless as well as tin steel tube. Knowledge and practice make a perfect flare. We have outlined the steps in the process for both tools. By following these steps you will achieve a perfect flare every time.
    Use the right tube
    Not all tubing is the same, there are many grades and thickness. This makes the difference in being able to flare the tube. Automotive tubing is .028 wall thick. Thicker tubes .035 and .048 are a nightmare to bend because they are thicker. The thicker tube also reduces the inside diameter so your brake fluid flow is restricted.
    Steel Tube: has a tin coating for corrosion resistance. The heating process of the tubing for the coating causes the tube to be hard or soft. Also depending on what the tubing is made for it can be single wall or double wall tube. On single wall tube the weld seam is clearly visible and this tube will be cheaper and much harder to work with (Not worth it). Double wall tube is much softer and there is no seam. Some steel tube has no coating and while it saves money it will rust almost right away. Inline Tube uses the best tube on the market, it is doubled wall with a tin coating on the outside and a copper coating on the inside made to automotive specifications to be effortless to end form and bend. Tubing has many uses and general tube from the supply house has general specifications. Inline Tubing is specifically for automotive use and ordered to your specification.
    Stainless Tube: has many benefits. It will never corrode and it has a bright glossy finish that can be polished to chrome but requires a better tool to flare. This tubing is also on the market in many different grades, thickness, and hardness which all play a role in how hard it will be to flare. General tubing can be very hard to flare and the finish may not hold up depending on the composition of the tube. Inline stainless tubing is 304 grade, 028 fully annealed, with a bright finish. This all means that it is the easiest to to work with on the market.
    Use the right Tools
    Not all tools are the same, the cheap $25 dollar tool is designed for copper tube and barley gets the job done. In tools you get what you pay for. A good flaring tool can cost between $65.00 and $110.00. Good tool names are Ridge, Blue Point, Imperial Eastman, and Inline Tube carries them all.
    Prep the tube 45 degree
    Cut tubing with a wire fiber wheel not a tube cutter. The fiber wheel is a clean heat free cut and it is fast. The tube cutter heats up the end causing work hardening and also roles the inside edge in making it very difficult to flare. Once the tube is cut it will have a burr on the inside and outside of the tube, this burr must be cleaned off. To take care of the outside we use a flat file working a 45 angle around the edge of the tube. For the inside edge we use a drill, center drill, or chamfer bit.
    Ready for flaring 45 degree
    Once the tube is prepped the end will come to a point. By removing material from both the inside and the outside edge the tube will fold over much easier when we begin flaring.
    Measure the tube 45 degree
    Advance the tube through the die block so it is at the same height of the lip of the ****on. The proper distance for the tubing to be raised above the die block is gauged by the head of the appropriate ****on. The second ridge for the 3/16 ****on is used. Make sure the tube is advanced flush with the top of the ****on. Use the side clamp to hold the tube and it can be helpful to clamp in a vise to hold the tool. Now place the ****on with the pin in the tube and line the tool over the top of the ****on. With the tube clamped start turning the top handle until the ****on die reaches the die bar. You will feel the tube forming as you are turning. DO NOT OVER TIGHTEN the tool. When the ****on die is at the die block you are done. If the tool is over tightened the small ****on will usually fail by cracking into two. If you are unsure stop early. This is considered the first operation of the double flair.
    Do not over tighten 45 degree
    Let the tool do the work 45 degree
    Remove the small ****on die and tighten the handle again, this will fold over the tube to form a smooth uniform flare. Loosen the tool and take a look. This is considered the second operation of the double flair.
    Inspect your flair 45 degree
    This basically shows the three operations. Cut and debur your tube, first operation, second operation and you are finished. Now inspect your results. There are many thing that can go wrong so if you do not have a perfect flair with the tips below try again.
    Tube Cutting - Do Not use a tube cutter. Cut the tube with a fiber wheel or metal cut off saw.
    Prevent Tube Slipping - If your tube is slipping from the tool you may clamp it in a vise or clamp the opposite end with vise grip pliers.
    Shallow Flairs - Are a result of not allowing enough material to stick up through the die block. The proper distance is measured to the top of the ****on. This distance may vary so if the flair is shallow advance more tube, and if the flare is too much lower the tube, this height may vary on different size tubing.
    Die Cracking - The ****ons for the double flair should never be tightened against the die block. If this occurs the ****on will crack. DO NOT OVER TIGHTEN THE TOOL. This ****on may also break if not enough tube is advanced thru die block and ****on bottoms out.
    A Final Note - Fairing tube takes practice and an understanding of how the tool works. Once the practice is put in the understanding will come. Read the instructions before starting, they will save you lots of time in the end.
    Prep the tube 37 degree
    Cut tubing with a wire fiber wheel, not a tube cutter. The fiber wheel is a clean heat free cut and it is fast. The tube cutter heats up the end causing work hardening and also roles the inside edge in making it very difficult to flare. Once the tube is cut it will have a burr on the inside and out side of the tube, this burr must be cleaned off. To take care of the out side we use a flat file working a 45 angle around the edge of the tube. For the inside edge we use a drill and a center drill or chamfer bit.
    Ready for flaring 37 degree
    Once the tube is prepped the end will have a chamfer on both the inside and outside edge. You want the end of the tube to be as flat as possible with no burr. If the end of the tube is not prepped when a flair is applied the edge will be rough and dig into the component.
    Measure the tube 37 degree
    Advance the tube through the die block so it is at the same height of the block. This is the same for all sizes of tube. Use the side clamp to hold the tube and it can be helpful to clamp in a vise to hold the tool. With the tube clamped start turning the top handle until the handle pops and spins with no effort. You will feel the tube forming as you are turning. You can not over tighten this tool once the cone reaches the die block it pops and you are done. This tool has a off set head so it works the edge of the tube out slowly for a perfect flair.
    Inspect your flare 37 degree
    This is a single flare so if it is shallow advance more tube up through the die block and if it is too big reduce the amount of tube though the block. Since tubing varies so will this height. It will take a few times before it is just right. Since the single flair has a rough edge you may want to file any burr off the edge before installing.
    Consult your mechanic
    This page is intended for use as a basic guide to help install new brake and fuel lines. If you are unsure about any part of the installation procedure, please consult a certified professional mechanic for ***istance. Inline Tube ***umes no responsibility or liability for improperly installed lines.
    Quick Tip: Tube Flaring
    Read the instructions - Stainless and steel tube flair the exact same way. The steel tube is a bit softer and this makes it easier to flair but if you follow the steps the stainless will come out just as nice.
  11. ratman
    ratman
    Thanks for taking the time to write that up. Very helpful as I want to use stainless steel lines
  12. mustangmike6996
    mustangmike6996
    from the D
    The inline tube flaring tool (same as eastwood or K tool) works beautifully. In fact, my wife flared her first line. I was in the garage at 22 degrees so the stainless was even harder to work with but still made the best flare I have made yet. I did 37 degree AN,45 degree double inverted, ISO stainless and mild steel. The only time I had an issue was when the tube end wasnt cared for or filed/chamfered. People state they like the master cool hydraulic kit but have had issues. This is the reason I stuck with the manual tool. I have 200 into the tool from inline tube (cheaper than the others by 30 bucks) and I have the 37 degree die from eastwood for 100 more bucks. The master cool hyd kit comes with all of that plus you can do quick connects, so thats the decision you have to make.
  13. nmpontiac
    nmpontiac
    from Taos, NM
    While I'm not sure exactly what lines you're running, I've used Swagelock stainless fittings on brake systems and fuel lines and really like them for several reasons - no flaring and they are overall shorter than AN. They make all sorts of NPT to tube adapters and other useful stuff. The picture shows a 3/8 tube to -6AN fitting and the bottom is 1/4 tube to 1/4 npt.
  14. rfraze
    rfraze
    Isn't that way more than a 37 degree Rigid? Mine works very well, input for others who are still shopping.
  15. mustangmike6996
    mustangmike6996
    from the D
    It is more but I would say its worth the price for the ease of the job and quality flare.
