Technical 40 Ford frame swap
Discussion in 'Traditional Hot Rods' started by 47chevycoupe, Oct 5, 2013.
  1. 47chevycoupe
    47chevycoupe
    from Finland
    I know this question has been asked before could not find it. Is the sedan/coupe frame the same as a convertible on a 1940 Ford?
  2. J. A. Miller
    J. A. Miller
    from Central NY
    I believe I read once that convertible frames were made with 1guage thicker steel. The convertible frames also have extra braces in the cowl area that run from the frame rail to the x-member.
  3. saltracer219
    saltracer219
    This is true Convertible and Pickup frames are made of slightly heavier gauge material. Yes they will interchange with all the other p***enger cars and light trucks.
  4. 47chevycoupe
    47chevycoupe
    from Finland
    I thought they were almost identical. I looked at this car last year but he supposedly sold the car to someone else. I think he wanted more money than what we agreed to. He parted the car out and what's left is the frame. I leave Finland in the morning and when I get home I will go pickup the frame.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I was under the impression they were the same except a little reinforcing in the cowl area. HRP
  6. 40FordGuy
    40FordGuy
    The frames are the same; Convert and station wagon have a piece between the left side outer rail, and the X, under the driver side floorboard. I read that car frame is 20 ga and the pickup is 11 ga.
    If you need 40 frame measurements, I can email them.
    HAPPY RODDIN' 4TTRUK
  7. J. A. Miller
    J. A. Miller
    from Central NY
    The cowl braces are on both sides, and I think you meant the car frames are 11 guage and the truck/convertible/woody frames are 10 guage.
  8. DD COOPMAN
    DD COOPMAN
    I concur...11 gauge and 10 gauge. DD
  9. R.W.JOHNSON
    R.W.JOHNSON
    Yes, i have done this on running & rolling frames several times, no problems, & yes there are 2 small additional braces on the convertible, u shold be fine, cheers, :)
