Does anyone know what was in the old time carb cleaner? The new stuff doesn't work very good. I think the old stuff had methylene chloride in it. I think that's still available at the hardware store. We used it for gluing Plexiglas together . The last batch of the good stuff had water on top of it in the can. The can rusted out so I had to get rid of it. Something I regret now,. JB
Not sure about the ingredients but, equal parts vinegar and water in a pot, works pretty good. I put the pot on an old Coleman stove and get it almost boiling.
I think the only thing that is the same between the old Berryman's Chem Dip and the new is the smell.
Way back then we used Trichlorethlene and Carbon Tetrachloride for a lot of greasy cleanup.. Dangerous and lethal on parts you would weld.. Phosgene gas..
Here is what I use. The bond seam is between vent 2&3 from the left. http://www.eplastics.com/Plastic/Plexigl***_Glue And for ABS http://www.eplastics.com/Plastic/ABS-Glue Here is the website http://www.eplastics.com/Adhesives http://www.mcmaster.com/#weld-on-adhesives/=pjnirn ABS-Glue Is used to bond and rework interior trim panels. Later today I will post a picture of a AC vent lenghtened for the dash. Vent's are from Dodge Dakota rear roof ac vent. .
I don't want to glue Plexiglas. I want to clean the carburetor. The new stuff is like diesel fuel or similar and doesn't remove all the sludge. I contacted Gunk and they won't tell the formula for the old stuff. Product liability. worked at a place that used 111 trichlor. Freon and several other bad things to clean glue off airplane antennae. The stuff really worked. I don't want to make the stuff and sell it . I just need to clean the carbs on old cars. JB
I think that's what I use to build plastic models (I got from plexi store). It does not glue anything. It's "hot" enough to melt the two pieces of plastic together as it evaporates. More like welding plastic rather than an adhesive. So that's probly not an ingrediant
We got some Berryman chem-dip professional and it works real well. And we have used Master carb and parts cleaner that has worked the best.
eazy off oven cleaner has lye where rubber gloves and eye protection...used it on a Stromberg 97 with a old tooth brush,clean as a whistle tried gum out a waste of time and money
oh forheavens sake use pinesule disasemble carb and soke for a couple days then rinse off in a good cleaning solvent it will look like brand new
We have been using this stuff, works awesome, you can get it on Amazon or at a Yamaha Shop, water based, super strong
I got awesome **** from a caterpillar heavy equipment mechanic ~ called strife? that **** ripped paint gasket sealant off with no problem!!!!!
