Projects knock off AC compressors ? who's using them
Discussion in 'The Hokey Ass Message Board' started by Rustytoolss, Nov 29, 2013.
  1. Rustytoolss
    Rustytoolss
    I know you get what you pay for. And when is a deal, not a deal ?
    But I find a $81.00 difference between a VA compressor, a Amazom.com sanden 508 compressor.
    So how many of you went the cheaper way ? was it a good choice ? or big mistake ? What do you think ?....Would you do it again ??
  2. Gman0046
    Gman0046
    What makes you think Amazons Sanden 508 compressor is a knock off?
  3. HOTRODPRIMER
    HOTRODPRIMER
    You said it yourself,,you get what you pay for... HRP
  4. Doppleganger
    Doppleganger
    from ...
    I have a good friend who sold AC components for years - the fellas he sold out to are great and very reasonable.
    I've been using Seltec and Sanden compressors for years - these are OE for many makers - with no issues at all. They are on average $300.
    The $99-159 feebay models are another story. Several bought them then wanted me to install them - only way I would was with zero warranty because if they lasted a year before puking a bearing or main seal, it was a successful buy IMO.
  5. Rustytoolss
    Rustytoolss
    it says Sanden 508 "style" double V belt compressor.
  6. Rustytoolss
    Rustytoolss
    And how often/ soon, did a knock off fail ?
  7. hotrodhoodlum
    hotrodhoodlum
    as the saying goes you get what you paid for
    I have always recommended Sanden for the compressor
    and Vintage Air for the components and never had negative feedback
    on either products
  8. Doppleganger
    Doppleganger
    from ...
    80% of the time it was within 12-18 months. About 8-10 yrs ago, I would get 3yrs + out of them. After about 2007-08, the failure rate was so bad I couldn't afford to buy them anymore - for time's sake alone. Some would blow the seal at the initial charge. I went to Sanden and Seltec's exclusively after that and with about 20-25 units bought/installed, had one I returned for a noisy clutch. Otherwise it worked fine.
    Of course, the major deal with swapping one out is a new drier and (if applicable) a new orifice tube. Both are cheap and usually required by the compressor manufacturer for any warranty.
  9. gimpyshotrods
    gimpyshotrods
    You want to borrow $81?
  10. Gman0046
    Gman0046
    rustytoolss, your first post didn't say "Sanden style compressor". I wouldn't touch it with a 10 foot pole. Real Sandens are not that much more expensive then the knock off's. Buy the real one. I've never had a problem with a real Sanden.
  11. Rustytoolss
    Rustytoolss
    You just told me everything I needed to know. Thanks
  12. Rustytoolss
    Rustytoolss
    Thanks for the offer. I'm going to buy a REAL SANDEN
