I did some horse trading and will be picking up a rusty 1950 style line 2 door next week. I'm planning in trying to keep this build as traditional and economical as possible by investing elbow grease rather than ordering parts. No bags, a/c, etc. are in the cards. The only modern concessions that I will be willing to make are brakes as this will be a family vehicle and possibly an overdrive transmission. I'm debating keeping the 216 and factory driveline and wonder how poorly I would be able to keep up with traffic. This will not be a daily driver. Thank you and happy turkey day! Posted using the Full Custom H.A.M.B. App!
I had a '51 Fleetline with the original 216. I swapped a powerglide center section into the original torque tube rear...3.55 gears vs. 4.11s. There was a noticeable improvement. Top end went from 50 to about 65, 70 if you pushed it a bit, so yes it will (kinda) keep up with modern traffic if you stay in the right lane. A tire burner it won't be. Chris
put a 55-64 rear end in it with like 336 gears in it and you can cruise 75 all day with low rpms. ive don't the swap 3 or 4 times. easy, cheap and effective
Thanks for the responses so far. What is required to convert to open drive or do I have to swap transmissions?
Devin - I *think* one of the vendors (Stovebolt, maybe) makes an adaptor kit that will allow you to mate an open rear to a torque tube transmission. Honestly, tho, if you're going to go through the effort, just swap in a T5 with an S10 tailshaft. You'll get an OD transmission that will get you up to 70+ without to much of a problem. Chris
the biggest problem with that in this case is there goes his budget. OD with is 216 will sure make the think a lot happier though!!
get exciteted when you you come across a tractor on the road cause you finaily get to overtake something.
Run it like it is. It's not a daily driver so..... Later u can make changes. That keeps it budget minded. I got a 216 in my 38 pu
Tough as nails, slow as ****. Welcome to the club, you can do burnouts in the snow or dirt. Still cooler than a trailer queen ! Posted using the Full Custom H.A.M.B. App!
There is really only a couple of ways with keeping the 216-235-261 style of engines; you'll need a truck style bell housing, or a 55-57 p***enger car bell housing, in order to keep the side/bell housing mounts. Then you'll need a 55 or later transmission, drive shaft, and open rear end of your choice. The other involves an adapter plate, and is usually used along with a 5 speed O.D. transmission; the rest of that conversion is basically the same. Patrick's make a kit to use a Saginaw 3 or 4 speed and retain the torque tube, but it requires you to send them your main shaft for modification; they may have an out-right" kit now. The 49 and 50 cars had the Huck brake setup, the 51-54 have the better Bendix brake setup. Lot of work to convert the brakes over however, as it requires a backing plate swap. Convert to a Powerglide, complete torque tube/rear end from a 51-54 will get you the better 3.55 gear ratio AND the better Bendix brakes. Then convert the fronts over to Bendix style brakes. Several vendors make power brake set ups. Check in with ChevyTalk.Org, in the 49-54 forum, where there are a lot of devotee's of these cars. That's about all I have. As far as the shame in keeping the 216, throw a nitrous kit on it, and you'll not have to deal with the shame for very long (just kidding). Butch/56sedandelivery
Thanks, if the current engine checks out ok then i will go that direction, otherwise I will look for 235 and open drive. I do have a spare saginaw 4 speed and some 57 chevy rear beak parts and pumpkin. That may he th direction I go. Great advice all Posted using the Full Custom H.A.M.B. App!
No there's not i ran one in a 46 chevy truck with n-50-15's on the back(things we do when it looks cool) i don't reccomend it. But you could run something under a 225/75/15 or 215/70/15 and not stress it to much.Good luck they can be kool cars.
The "cool" factor increases exponentially if you put it in a 4 door, add a gl***pack and a foxtail on the antenna. Extra points for curb feelers, angel hair on the package shelf, and *** lights.
Hahaaaa. I do have a running SBC I could throw in there, but I want to resist that temptation and keep the build focused towards early customs. Also I'd like to learn more about inclined. Posted using the Full Custom H.A.M.B. App!
There's no shame just a little inconvenience. If it is the original motor it is babbit bearings and low pressure lubrication. Keep it down to 50. Maybe 55 if the motor is in good shape and you feel lucky. I would keep the torque tube drive (less work) but change the rear gears and maybe the engine. A newer 235 or torquey 261 GMC truck engine will bolt in.
He makes a good point. They sound fantastic with a great set of pipes on them and if you don't push them too hard they are pretty reliable. You just have to plan any trips out of the local area so that you have plenty of time to get there without pushing the car too hard. If you are in the habit of traveling alone that isn't much of an issue and you end up doing the two lane thing rather than the big road thing and get to see cool stuff at an easier pace. The big rub with an engine that can't keep up with the big engine boys is if you belong to a club that likes to travel together and the trip leader likes to run at the speed limit or above. They always get whiny when they have to slow the pace for the slower running cars and can't run 85 in a 70. Going slower on a road trip isn't all bad as it becomes more about the actual trip than the destination. Instead of running at 75 on the freeway you run at 50 or so on the two lane and see the old barns, old cars and trucks beside the barns and stop at yard sales along the way.
I'm going to try to get her to kick over and run her till she drops then look for a 235, 261 or a Jimmy! Posted using the Full Custom H.A.M.B. App!
X2 in spades!! Locally, the tedium of driving the I-5 between Bellingham and Portland is enough to put you into a coma. SR-9 is so much more interesting. Get off the interstates, and SEE the USA.
These are good engines if you keep the RPMs down. I have a 181 (pre-216) in my 35 Master Delux. Sat for lord knows how many years. New wires, points, and fresh oil and a 12v in line with the 6v battery and it started right up. You give them gas and spark and they will start. Besure to check the valves if you are having problems. Set them before you start. I have had a couple of 'old-nonrunning' 216's that the valves were so loose, they didn't know what to do. Set 'em up, not too tight and it solves a world of problems. build'em to drive'em.
From a guy who rocks a 144, run it until it explodes, and worry about it then. I'd put an S10 T5 behind it, on an HRW adapter, and a Walton Fabrication crossmember. Mid 70's Camaro axle.
Wow, these would really take my concept to the next level!! http://www.ebay.com/itm/Nostalgic-s...ries&hash=item519d466218&vxp=mtr#ht_91wt_1124 Starting to think about building this deal myself!!
216 will get the job done...But please use a reasonably quiet muffler..The world doesn't need another slow *** loud 6 cylinder
Drive her til she lays down, that's my plan. 55 and mine is smooth, stays cool, and seems happy. Keep the motor from getting hot and good oil pressure is key. Chevrolet built them well, from the 30s to the 50s. Tough old grocery getters. Good luck to you.
