47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. kscarguy
    kscarguy
    Don't forget to put a drain hole or two into the lower edge of the fender step insert.
  2. good tip :)
  3. woodbutcher
    woodbutcher
    :D Also,don`t forget to put a small bevel on the up side of the drain hole.Got that little tip from an old time body man back in the late `50`s.
    Good luck.Have fun.Be safe.
    Leo
  4. WOODEYE
    WOODEYE
    Corvettesander, I have just spent a very enjoyable 2 hours following your build so far from start to present. Your talent level is just unbelievable. Thank you for letting us follow along. Take care and be safe.
  5. will do :)
    thanks
    this weekend i have changed something at the rear, i was not pleased with the license plate cove and cut it out.
    i will relocate the license plate to a bracket somewhere lower
  6. nothing mayor going on right now
    but working on some small things like on the door dovetails
    and finished the vent door pneumatics
    and started with some lower interior panels the rest will be covered up by the seats
  7. farmer12
    farmer12
    Great work as usual!
  8. today i have finished the last interior panels,
    last thing i need to fabricate to finish the cab is a shroud to fill the gap between the cab and radiator, i made some measurements and now i am ready to remove cab from the ch***is.
    Oh my measurements are in metric ;):p
  9. today i have made the radiator shroud
    i have abouth a 1/2 inch of clearance between the shroud and radiator
    that will be closed with rubber eventualy
  10. 36 ROKIT
    36 ROKIT
    Very cool rad./shroud setup. I'm ***uming the box in back of the lower grille will allow fresh
    air to p*** through, under the seat?
  11. shopdawg
    shopdawg
    from alberta
    Sander-really like your build. what did you do with the gap between the firewall(top inside ) and body ? I moved the original tin closer and then used a urethane seam filler. You have to seal this up or there is major wind noise inside the cab.
  12. yes
    nothing yet but your right, it needs to be done
    funny thing is i was looking at it tonight when i removed all interior parts and the dash :)
  13. have been working on the inner shroud to line up to the duct/tunnel
    so it forces tru all the collected air.
  14. tinwizard
    tinwizard
    from Northwest
    Sander,
    Fascinating build .... loads of innovative ideas make this the best COE build I've seen a long while. One question for you. I noticed in a number of locations that you have used what appear to be either ****on head bolts or large flange pop rivets to hold tin panels in place. Are those temporary .... or are they going to be used permanently? I haven't been able to zoom in sufficiently to get a good look at what those fasteners are,
    but do like them a lot, and see them as a good alternative to old school rivets.
    Keep up the great work and the photo coverage. You are teaching the rest of us a lot.
  15. kscarguy
    kscarguy
    Just a thought...If it were me, I would leave the bottom of the shroud (just in front of the radiator) "off or open" so leaves, debris, or whatever, can fall off the radiator and not be trapped inside the shroud. The air will get to the radiator even without the lower portion.
  16. cagedruss
    cagedruss
    We have been using this type of air duct system for years on Late Model stock cars. Close it off. Air follows the path of of least resistance like Electricity and Water. In slow speeds the air will want to go out the bottom than the more restrictive cooling fins. Add a screen across the front of the air intake to keep the debris from getting inside.
    Awesome work by the way.
  17. hi for an other build (55 chevy pickup) i used the allen head bolt type, but for this one i will use slot type bolts
    as the look is more authentic. they are both in stainless steel
    i think i will just close it up and make some small drain holes for release of water
    and a screen in front to block debris as said by cagedruss
    thanks for the tip :)
    tonight i have almost finished the shroud duct work
  18. tinwizard
    tinwizard
    from Northwest
    Sander .....
    Thanks for the closeups of the fasteners. I do like the idea of the authentic look of the slotted stainless cap screws. What manner of nut arrangement are you using? Some variety of captured type??
  19. RMR&C
    RMR&C
    from NW Montana
    I wonder if there will be any noise from air rushing through the duct at highway speeds?
    Great work throughout the entire build!
  20. gatz
    gatz
    An added bonus !!
  21. castirondude
    castirondude
    Surely much less noise than original air rushing + fan running + engine running :)
    He's making the duct super smooth that will help a lot. Maybe some rubberized coating would help as well? Although that stuff is nasty, probably better to just use sound deadening material on the interior floor.
    Sent from my Verizon 4G LTE smartphone
  22. i am using rivet nuts
    it probably will make some noise but i think there will be a lot more wind noise from windshield doors rain gutters etc...
    i will also add sound deadening material to the floor and firewall
    tonight i have lift the body from the ch***is again to work on the floor and air duct, most of it is still tag welded
    i will remove the lower sheet metal from the duct to add some beads
    to add some more strength and reduce resonance and then weld it back in
  23. jfreakofkorn
    jfreakofkorn
    good progress being done on this project ....
    i have been looking forward to the updates ....
    keep up the good work =)
  24. Wow, great progress Sander!! I have learned a lot from this build, very well done!!
    Bill
  25. bengeltiger
    bengeltiger
    Excellent build accompanied by great pictures and explanations. Thanks for sharing this with us. Subscribed!
  26. today i have been working on the air duct again.
    removed the lower sheet metal from the duct and made a cover over the floor braces that p*** tru the duct, to eliminate any wind noise comming from that part at least ;)
    by adding the cover and to avoid getting to much air flow restriction,
    i have made a curve to the lower sheet metal plate.
    and made some drain holes
  27. finished all welding and sheetmetal work on the cab today,
    made a cart to roll the cab around for block sanding and primer/paint etc.
    now i will get to some detail work, like changing the look of the modern gas pedal
    made a stainles steel pedal
  28. I've really enjoyed following along on your build and I like seeing how you solve various issues and engineer solutions.
    I do have one question, did you use a weld through primer inside the air duct? Oh, one other thing, how does moving the engine back affect the designs of the ch***is? I mean, the factory designed the dynamics of the ch***is to work with the engine situated up front over the suspension so I was just curious if moving it back would have any postivie or negative affects. Sorry if that's a stupid question.
    Keep up the great work!
  29. i am using electrolytically zinc coated sheetmetal (Zincor)
    its ideal for closed or boxed aplications its only minor disadvantage is that its a bit tougher to form . i dont know if this type op sheetmetal is available it he Usa ?
    the ch***is is strong enough to have engine behind the cab.
    and i think the weight distribution is close to what the chevy 3500 originaly was,
    with the cab in the location where the engine previously was.
  30. castirondude
    castirondude
    I installed a 5 ton building a/c a few years ago and the ducting that came with it look like what you describe. Metal roofing also uses this a lot. It can be out in the weather for a few decades without rusting.
    There is also aluminum coating this is usually used for exhaust systems.
