Acrylic enamel chipping easily?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Nov 30, 2013.
  1. oldrelics
    oldrelics
    from Calgary
    My 3 month old acrylic enamel seems to chip fairly easy, like when I bolt something on or dropping wrenches. Is this just the nature of AE or do I have adhesion problems. I used poly primer sanded with 320. Sealed with epoxy and shot AE after 1hr as per instructions.
  2. oldrelics
    oldrelics
    from Calgary
    no ideas guys?
  3. 5559
    5559
    from tn
    too much hardener???
  4. mikhett
    mikhett
    from jackson nj
    POLY primer is THICK!Ideally all coatings should be a minimum mil thickness the more material the easier it will chip.
  5. builderforu
    builderforu
    Can you determine what layer is chippimg? Color off the epoxy or epoxy off of primer. How long was primer applied to parts before being coated?
  6. Not sure of the brand you used. But poly primer should never be sprayed over like that. It need to be primed with a good 2k surfacer. It is nothing more than sprays le body filler. You wouldn't paint over that right?
    But I have also seen chipping issues with AE.
  7. oldrelics
    oldrelics
    from Calgary
    Everything was mixed according to the instructions. Proper temps/reducers used. I think the color is coming off the epoxy. Its not a typical poly, its a hybrid (evercoat Finishsand). The poly was dry for months, the epoxy said you can spray color after 30 mins and no later than 7 days.
  8. was it Sherman Williams I use it once and never again for the same reason
