Projects 40 chevy coupe project
Discussion in 'The Hokey Ass Message Board' started by cashcustomcars, Oct 20, 2013.
  1. cashcustomcars
    cashcustomcars
    I picked up this 40 chevy coupe about a year ago and finally got some other projects finished up so now it's time!! It had a early 70's firebird front stub on it when I got it, but it was not on there very pretty, and it didn't lay frame with the suspension bottomed out. The plan is to cut off the stub, Z on a 63 bel air clip, step notch the rear and get it down where it should be. The previous owner had also installed firebird leafs on the back and a positrack g-body rear axle. The leafs have to go and a new ladder bar type air bag suspension will replace it. Power will probably a 350/200r4 I pulled out of a 62 bel air this spring. That's all I got for now, let the choppin began!!
    ImageUploadedByH.A.M.B.1382320574.883171.jpg H]
  2. cashcustomcars
    cashcustomcars
    Better wheels, no rear leafs and coils pulled out. Close bit no cigar on elevation.... ImageUploadedByH.A.M.B.1382320718.081340.jpg ImageUploadedByH.A.M.B.1382320752.742739.jpg
  3. cashcustomcars
    cashcustomcars
    ImageUploadedByH.A.M.B.1382320875.689381.jpg Got the frame pulled off, old clip cut off and rails straightened up again. ImageUploadedByH.A.M.B.1382320897.481638.jpg
  4. zjerry
    zjerry
    Looking Good..
  5. Butch Clay
    Butch Clay
    Nice! I'm working on a 40 sedan, this will be a good education for me.
  6. cashcustomcars
    cashcustomcars
    Got a few more things done on the 40 lately. The 63 stub is in place a tacked on straight and square (with a lil help). I z'd it about 4 1/2" so it should lay frame and then some now. Next is to finish up welding in the stub and notch the rear. Stay tuned! ImageUploadedByH.A.M.B.1383188143.797814.jpg ImageUploadedByH.A.M.B.1383188160.697356.jpg ImageUploadedByH.A.M.B.1383188181.913358.jpg ImageUploadedByH.A.M.B.1383188194.513982.jpg
  7. Butch Clay
    Butch Clay
    Looking good!
    Sent from my XT901 using H.A.M.B. mobile app
  8. jfreakofkorn
    jfreakofkorn
    nice progress .....
    and it looks like that you have help =)
  9. cashcustomcars
    cashcustomcars
    Tonight I got the side plates tacked into the z, hopefully tomorrow I can get the end plates welded in and complete the z, then it's time to tackle the rear step notch.
  10. cashcustomcars
    cashcustomcars
  11. cashcustomcars
    cashcustomcars
    The front end is all welded up and done now. Got the frame set back in the ground to figure out how much step in the rear. ImageUploadedByH.A.M.B.1383425660.086408.jpg ImageUploadedByH.A.M.B.1383425677.778720.jpg ImageUploadedByH.A.M.B.1383425702.462058.jpg
  12. cashcustomcars
    cashcustomcars
    The rear step notch is done. Now I'm going to start building the rear suspension. Prob gonna go with a ladder bar type with a watts link setup.
    ImageUploadedByH.A.M.B.1384022844.885640.jpg ImageUploadedByH.A.M.B.1384022869.083156.jpg ImageUploadedByH.A.M.B.1384022880.615626.jpg ImageUploadedByH.A.M.B.1384022889.499071.jpg
  13. chevy54man
    chevy54man
    from NC
    Man she's looking good
  14. cashcustomcars
    cashcustomcars
    Thanks!
  15. 64Kaddy
    64Kaddy
    from SoCal
  16. cashcustomcars
    cashcustomcars
    Thanks. I think the main difference between the two is in c-notches I've done on other things is I left the rails in place, but cut out a half circle piece above the axle and welded in a half section of 6-8" pipe instead of completely changing the frame rails. Works good if you don't won't to cut of the floors, but it wasn't gonna get me low enough for this project.
  17. cashcustomcars
    cashcustomcars
  18. cashcustomcars
    cashcustomcars
    Over the weekend I got the trailing arms put in place and the air bags mounted onto the arms.
  19. cashcustomcars
    cashcustomcars
    ImageUploadedByH.A.M.B.1385949148.934232.jpg ImageUploadedByH.A.M.B.1385949156.520728.jpg ImageUploadedByH.A.M.B.1385949169.753412.jpg ImageUploadedByH.A.M.B.1385949186.103599.jpg
