History Hotrod pipes! Lets see'em!
Discussion in 'The Hokey Ass Message Board' started by redlineracer42, Dec 2, 2013.
  1. I like a rod when ya can't see the pipes hangin down like an after thought...Ya know the kind...Killer car,much thoughtout build...then the exhaust system hangs down lookin ugly.....Lets see'em guys...plumbing...
  2. Here's a shot from the bottem...Flowmaster says tailpipe difference ok as long as from header to muff is equal...
  3. mustang9093
    mustang9093
    from Indiana
    How about baffled zoomies.
  4. 29 Speedster
    29 Speedster
    from Colorado
    Our Speedster has a unique tuned header.
  5. leroux
    leroux
    from SoCAl
    @29 speedster.....
    Wow....that's nice..make mine look like ****
  6. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    This is the way exhaust should be in my mind.
  7. Leviman
    Leviman
    That's so *****in!
  8. tfeverfred
    tfeverfred
    That there is ART.
  9. hotroddon
    hotroddon
    Tuned? To what, with all those different lengths :confused:
  10. chubbie
    chubbie
    tail pipes together is like putting your stereo speakers together......MONO you could of had stereo!!!!!
  11. 29 Speedster
    29 Speedster
    from Colorado
    They are all the same length, for low end torque.
  12. love it!!!!
  13. youngsspeed
    youngsspeed
    I didn't want the "off the shelf" header that I have on my car. I like the lakes look but don't like exhaust outside the frame rail. So here is what I came up with ImageUploadedByH.A.M.B.1386741436.597263.jpg ImageUploadedByH.A.M.B.1386741450.099003.jpg ImageUploadedByH.A.M.B.1386741464.935128.jpg ImageUploadedByH.A.M.B.1386741487.811663.jpg ImageUploadedByH.A.M.B.1386741503.172896.jpg
  14. Kustomism
    Kustomism
    ImageUploadedByH.A.M.B.1386744178.520245.jpg ImageUploadedByH.A.M.B.1386744195.086676.jpg
  15. I just got my old headers back from the roadster although they aren't the best performance pipes they still look bad ***ed!
    Posted using the Full box of Crayons on the Kitchen Walls App!
  16. kennkat
    kennkat
    Fender-well headesr on a '41 Willys G***er Pickup.... Go-Kart! :):):)
  17. go-twichy
    go-twichy
    bam.[​IMG]
  18. 1971BB427
    1971BB427
    from Oregon
    I like to see pipes, as long as they're header pipes or chrome tips. It's all the stuff between headers and tips that I want hidden. But I also want the stuff between to be nicely routed if someone looks underneath the car!
    I used a holesaw to put a hole on the inside of my collector on the headers so I could weld in a 2nd collector off the inside. It allowed me to route the exhaust inside the frame rails, and also open the collectors without dropping the exhaust system.
    I ran my mufflers vertically inside my ladder bars, and painted the exhaust flat black with VHT high temp paint to help hide it. Over the axle and out the back, with 3" chrome tips angle cut to finish it off. Just an old hotrod, but wanted it to look clean.
  19. hotroddon
    hotroddon
    Well, except the Mean Effective length is Not the same. Every curve changes the length of the pipe as the flow sees it. Airflow through a tube is essentially laminar - it wants to go straight, every curve slows down the flow as it upsets the laminar property. So it you look at 1 versus 4, while they MAY measure the same length, #4 is longer as the exhaust flow sees it, and #2 & 3 are longer than 1 & 2. This is easily measured on a Flow bench.
    They do look pretty cool though, and probably work just fine, but they are not "True" equal length
  20. bonzo-1
    bonzo-1
    No stinkin pipes needed.
    A lot quieter than I thought they would be. Which is good.
    16 inch gl*** pack with the end cut off to match the inside diameter of the cone. The end cap has a 2 inch hole in it slides over the other end of the gl*** pack.
    I think I am going to make turn downs on the end caps.
  21. 29 Speedster
    29 Speedster
    from Colorado
    I stand corrected!.......but not concerned. For an engine that produces about 100 HP, and turns about 4,000 RPM, they work and sound just fine to me.
  22. hotroddon
    hotroddon
    Agreed :D
  23. fiat gasser
    fiat gasser
    A set I built for my Fiat
  24. carpok
    carpok
    from Indy
    Pipes I built out of stainless steel for my 55. Ron
