  1. flynbrian48
    flynbrian48
    "A" for effort man! I couldn't do it, and it gives me the idea of what it'll look like with the light/dark combo.
    Brian
  2. TP
    TP
    from conroe tx
    I appalogize for the picture. !t was the first time I tryed posting a picture and had to get help then. I thank you for your effort. How do I make the picture bigger? TP
  3. nitrobrother
    nitrobrother
    No need to apologize...as I re-read my comment I think I was more gruff than I intended. No doubt others will offer their insights, but here are mine: Usually images are sized after they're downloaded from the camera. I usually resize my pictures to 1024 x 768 for use here on the HAMB (good balance between file size and screen size). There are lots of image manipulation programs, most even free, that you can use to resize them. Some - like Paint, which comes with all Windows systems - are what you can do to do one-at-a-time jobs. Others are set up to do a-bunch-at-a-time in case you have a whole flock of images to do. I have seven image mangler programs on my laptop, because each one has different ease-of-use (Paint, Picasa) or features that don't exist in the others. For your image, once it's reduced in size too much, you can't really go the other way because too much "digital information" has been lost. Good luck, but it's easy to get addicted to it!
    The more important question is: Are the colors what you wanted (except for the white scallops on the dark blue version)?
  4. TP
    TP
    from conroe tx
    I like those but looking for a baby blue or powder blue I guess. The one looks nearly purple but I can go off of that. Thanks.
  5. TP
    TP
    from conroe tx
    Can we try a mint green with white scallops? Thanks
  6. Squablow
    Squablow
    The full '55 parking lights look good on there too, if I wasn't trying to keep the current paint job, I'd probably go that direction. I still like it with the current parking light setup though. Gets me excited to see it in place.
  7. npennington
    npennington
    from Arkansas
    Can someone change the white walls in these photos to non whitewalls please?
  8. themoose
    themoose
    A quick one
  9. nitrobrother
    nitrobrother
    Better? Or just different?
    With black taillight trim:
  10. partssaloon
    partssaloon
    Would you please show the truck with Real Rodder Wheels on it.
    Aluminum Spindle mounts in the front and Sprints in the rear (polished)
    Thanks
  11. flynbrian48
    flynbrian48
    Hmmm, it's good to see what seemed like a good idea brought to life, and realize it wasn't so good! Beautiful job on the chop, the top has EXACTLY the same proportions I have, but seeing the colors broken that way, I realize that doesn't work. I think the two tone color break should be an the top of the side spear, and the colors should be closer, less charcoal on the bottom. Discuss…
  12. James D
    James D
    Just messing around with an English Ford Zephyr...
  13. SouthUrn
    SouthUrn
    from US
    When utilizing two colors, designers strive for a 70/30 split.
  14. nitrobrother
    nitrobrother
    I was worried I'd taken the bottom color too dark. Thanks for the chop comments...pure luck, to be honest!
    This is the image I started with if someone else wants to take a whack at it.
    I'm taking a break and prepping for some job interviews! Cross your fingers...
  15. flynbrian48
    flynbrian48
    Good luck with the job hunt, and thanks for all the time you put into doing that 'Bird rendering!
    Brian
  16. Rot 'n Kustom
    Rot 'n Kustom
    Nice job!
  17. Rot 'n Kustom
    Rot 'n Kustom
    You do realize that Chevy and GMC made a Cab-Over-Engine (COE) in those years, right?
    It would be much simpler (in real life & Photoshop!) to start with a COE and slice and dice from there. Here's one of many I found on the Internet.
  18. brewsterg6
    brewsterg6
    Not my work, but saw this on the net, and saved it! Not really HAMB friendly, but the logo on the side is!
  19. flynbrian48
    flynbrian48
    That's a thread killer, right there.
  20. brewsterg6
    brewsterg6
    I thought it had a bit of GM Futureliner look to it... Ugly, but stylish!
  21. Rot 'n Kustom
    Rot 'n Kustom
    OK, then. Here it is:
    <a href="http://www.flickr.com/photos/davetartaglia/11326270845/" ***le="GMCSnubnose by DaveTartaglia, on Flickr">[​IMG]</a>
  22. Rot 'n Kustom
    Rot 'n Kustom
    You're welcome!
    I started with this 3/4 ton GMC pic I found on the 'net.
  23. iwanaflattie
    iwanaflattie
    So it could be done..and wouldn't look too shabby. ..
    Thanks again
  24. flynbrian48
    flynbrian48
    Where is there room for an engine/trans in this? Subaru flat 4?
  25. gonmad
    gonmad
    That's one heck of a load of wood!! LoL!
  26. OahuEli
    OahuEli
    from Hawaii
    Quite frankly, that looks a hell of a lot better than a standard COE made into a pickup. The proportions are pretty close to the mark. Me likee.:D
  27. bobj49f2
    bobj49f2
    Here's one I did for a thread on another board. I did a lot of work on it so I figured I'd drop it in here. I tried to deuglify it.
  28. Rot 'n Kustom
    Rot 'n Kustom
    Nah, Rolls Royce Merlin engine mounted in the bed. :D
    Even if you could find a place for a real engine, it would take a contortionist just to get in the cab. Maybe have to put the driver in place, then weld up the cab around him!
  29. Rot 'n Kustom
    Rot 'n Kustom
    Thanks, Eli.
    This was the first time I did a photo chop to someone else's sketch.
    My designs are usually from the "less-is-more school." :D
  30. Rot 'n Kustom
    Rot 'n Kustom
    Boy, that's an improvement!
    Wait... you started with the green one, right? :D
