Desoto Grill HELP
Discussion in 'The Hokey Ass Message Board' started by Atomic Kustom, Nov 19, 2013.
  1. Atomic Kustom
    Atomic Kustom
    I'am looking for a little info. on Desoto grills. I know '51 and '52 grills are the same but are the teeth on '53 grills the same as the earlier or different? Also is there a center tooth and then left and right teeth or are they all the same? Are they all the same height too or does that very also? Any help or info from you guys would be great!!
  2. porky55
    porky55
    My buddy has a 52 and a 53. From what I can tell they are the same except the 52 has the turn signals in the last tooth of each side. The 53 has the turn signals separate. Everything else seems to look the same.
  3. I have a '53,,they are different, approx. 7" outside to 8 I/2" in the center ,,,there are 11 of 'em total. Not sure about L & R.
  4. Atomic Kustom
    Atomic Kustom
    OK I had a guy tell me on the '53 grills that the center 7 teeth are the same height with the 2 on the ends being shorter like you said S****iron. He did also say there is a left and right, but didnt know if the teeth were the as used on the earlier grills. Does anyone know about '51 or '52 grills? What I am lookin for is the is the 3 center teeth for '51 or '52 grill, a center and a L & R tooth.
  5. thebearded1
    thebearded1
    .1953 Desoto Grills are different THEN THE others, there is a center tooth
  6. leadsledmerc49
    leadsledmerc49
    '51-'52 grilles are the same, having 9 teeth total with the 2 end teeth having park lights attached to them. '53 has 11 teeth total, with the outer 2 on each side now taking the place of the park light. There is a designated center tooth on both styles. With that being said, the "center" 7 teeth on the '51-'52 are the same as the ones in 53. The center is the tallest, and they all progressively get shorter as they make their way to the fenders. I know this because I was crazy enough to piece an entire 11 tooth grille together!!!:eek:
  7. Squablow
    Squablow
    The leading edge of the bumper pan is not straight, it's got a curve, so the angle at the very front of the teeth, where the teeth meet the pan just behind the bumper, are angled left or right to follow the pan, except the center, which is flat.
    I have a whole pan with bumper and teeth in my shop if you need any dimensions. I don't think the height changes at all on a 51-52 grille, I think the only ones that change height are the outer two on each end of a '53 grille.
  8. Rusty O'Toole
    Rusty O'Toole
    I have a Plym-Dodge-DeSoto-Chrysler parts book for 1951 -52. It shows the grille as the same for 51 and 52 DeSoto but each tooth is a different part number. There is a center #1, left #2, right #2 etc. all different.
  9. Atomic Kustom
    Atomic Kustom
    Thanks that answers alot of questions. Now I know for sure. Could I get those part numbers that would help in my search. I mainly need the 3 center teeth.
  10. leadsledmerc49
    leadsledmerc49
    Here's the part numbers for a '51-'52 desoto grille.
    1346792LH (park light)
    1346790 8911
    1346773 8909
    1346760 8907
    1346758 8905 (center)
    1346759 8906
    1346772 8908
    1346789 8910
    1346791RH (park light)
  11. Atomic Kustom
    Atomic Kustom
    THANKS! You guys are great
