T5(S10) transmission install in 1929 coupe
Discussion in 'The Hokey Ass Message Board' started by scrap metal 48, Jan 23, 2013.
  1. scrap metal 48
    scrap metal 48
    One of my winter projects this year was to replace the coupe's 3 spd with an S10 5 spd.. I read all the T5 threads here which helped me install the 5 spd without a hitch..I modified the T5 by cutting approximately 1/2" off the tip of the input shaft and 2" off the bearing retainer after comparing the 2 transmissions side by side.. I also used a die grinder to extend the splines on the input shaft.. I then made sure the GM Safari Van clutch disc(11" and 14 spline) would move freely on the extended splines.. More to come...
    DrewModelA likes this.
  2. 60srailjob
    60srailjob
    from nowhere
    Cool s**** metal 48, nice job, asking because not sure, you extended the splines do they have to be heat treated? good job!
  3. scrap metal 48
    scrap metal 48
    I then installed the trans after drilling holes for 1/2" bolts.. You can also see the difference in the trans mount from the 3 spd and the 5 spd.. A simple piece of flat plate welded to the trans cross member was all that was needed to mount the 5 spd.. Yet more to come...
  4. scrap metal 48
    scrap metal 48
    I modified the S10 shifter to accept an old swap meet handle buy cutting some off, threading some holes and flattening one side so handle could be attached.. One more installment...
  5. scrap metal 48
    scrap metal 48
    Here's a comparrison between the old 3 spd and the new S10 5 spd installed .. First pic is the 5 spd....
  6. scrap metal 48
    scrap metal 48
    I did not heat treat the splines and don't know if it's necessary....
  7. 60srailjob
    60srailjob
    from nowhere
    looks good man!
  8. scrap metal 48
    scrap metal 48
    I bolted the S10 trans to an early bellhousing and used a hydraulic slave adapted to it.. This set up worked fine for a year with the 3 spd trans so I didn't see any need to change it.. I made the slave bracket out of one old rumble deck lid bracket.....
  9. chopt top kid
    chopt top kid
  10. jarhead
    jarhead
    What year transmission is from the S10? Electronic speedo I'm guessing....
  11. scrap metal 48
    scrap metal 48
    Yea, it's an 1989 from a V6.. Just going to use the tach for now cause I'm still confused about switching to mechanical or trying to make an electric speedo work...
  12. slackcat
    slackcat
    Good job on the swap. Just finished the swap in my truck, used a '93 with electronic speedo. I'm going with the Cable-X converter this spring when I get some extra cash together.
    pecker head likes this.
  13. scrap metal 48
    scrap metal 48
    How much are the cable X converters??
  14. Kiwi 4d
    Kiwi 4d
    Around $340 , they work great, but a column clamp on electronic sppedo in a tach type cup would be way cheaper.
    [/B]
  15. mink
    mink
    from CT
    Why does the input shaft need modification, My camaro t5 bolted up to my 250ci without any issue. Just curious
  16. brokenspoke
    brokenspoke
    The camero has a different imput shaft.....than the S 10
  17. slackcat
    slackcat
    GPS is another option that works well.
  18. chopt top kid
    chopt top kid
    The input shaft on the S10 T5 is 9/16" longer than the Camaro T5 due to the S10 ****** was originally designed to bolt to a 4-banger Isuzu engine. Someone makes or used to make a spacer plate to bolt up the S10 ****** to a standard GM bell, but you still had to cut off or change out the bearing retainer to get the correct length on the throwout bearing carrier...
  19. scrap metal 48
    scrap metal 48
    Your correct chopt top.. Mine was from a V6 and it too needed the input shaft modified.. It finally warmed up enough to drive it some distance and I'm very satisfied so far..
  20. Uncle Phil
    Uncle Phil
  21. mgermca
    mgermca
  22. mgermca
    mgermca
  23. Adam F
    Adam F
    Looks good. I am about to do the same conversion. How much did you get your tailshaft shortened by?
    Did you use the old Saginaw gearbox mount?
    Adam
  24. scrap metal 48
    scrap metal 48
    Adam, I had to modify both the drive shaft and the trans mount...
  25. Adam F
    Adam F
    Figured as much....
    Sent from my GT-I9505 using H.A.M.B. mobile app
