Friend of mine has a GM 4spd setup that I would like to purchase but I need some help in decoding it first. The numbers I was able to get from it are as follows. CBF 378488 14030811 117 C-15390 There was also what appeared to be a saw blade like stamping with possibly a "NP" or "ND" inside it. ANy help would be appreciated. Thanks, Mike
Is it cast iron,, or aluminum ?? cast would be a saginaw unit ,, not good for much torque .. but they did come in some of the S S cars .. and vegas ....
that "np" makes me wonder if it's a new process ******. those come out of mopars... not gm's. stick a magnet to it. that'll tell you if iron or alum. google is yur friend. search muncie, m-20, m-21, m-22,rockcrusher(those 2 are the same),saginaw & t-10 & you should be able to get pics of each. hope that helps a little...mel
I don't know the part #'s but 1st and 2nd series Borg Warners were iron cases with aluminum tail housings and Muncies were all aluminum.Chevrolet p***enger car stick shift bolt patterns have been the same since like 55 thru the late 70's at least,if not the early 80's. G.M. Warners and Muncies have 2 shifter shafts in the side cover and 1 in the tail housing. Saginaws are all iron and have all 3 shafts on the side cover. Fords and Mopars were completely different animals. Also I don't recall ever working on a pre 70's Ford or Mopar that was aluminum Maybe that'll help,T.OUT
