Technical Firestone White lettering advise
Discussion in 'Traditional Hot Rods' started by 34hardhead, Dec 13, 2013.
  1. 34hardhead
    34hardhead
    from Richmond
    I have purchased a set of Firestone Blackwall Bias Ply tires for my very traditional 1934 3 window coupe. I want to paint or apply some sort of ink
    pen. but I do not want a bright white, I prefer something that looks old.
    any one know of a product like this, Coker tire is out of stock on there pens. and they only seem to show a bright white?
    Thanks
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    If you would choose the paint made for plastic you would have more of a choice of colors. You could even mix your own. I am sure it would last longer than those pens.
    Guys here paint the whole sidewall white with that stuff and love it.
    http://www.krylon.com/products/fusion-for-plastic/
  3. the-rodster
    the-rodster
    Yup, I use the dover white.
    Spray a little in a cup, dab on with a brush.
    Touch up when needed.
    Rich
  4. junk yard kid
    junk yard kid
    i just used a tire crayon from speedway. it didnt work very good.
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
  6. HomemadeHardtop57
    HomemadeHardtop57
    I use a white grease pencil that you can get at your local hardware store. It's just what you are looking for, cheap, and easy to apply neatly without mess
    Not the best pics .. Sorry
  7. the-rodster
    the-rodster
    Click the pic...... :)
  8. Nads
    Nads
    from Hypocrisy
    I used plastic paint in a spray can, it's been on there for years, it's faded to a nice ivory, still looks good.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Go to a art supply dealer and buy some 100% acrylic,,later if you get tired of the look you can clean it off with a product called Goof-Off. HRP
  10. JoKerr
    JoKerr
    One shot lettering paint 116-L ivory looks killer .
  11. JoKerr
    JoKerr
  12. 1971BB427
    1971BB427
    from Oregon
    The tire pens or grease sticks are very temporary. I've used them often, and in very little time they fade or wear off, and need touchup again.
  13. Besty34
    Besty34
    I used one shot it took a while to go off but as been on there for about three years
    shoebirdgal likes this.
  14. Kan Kustom
    Kan Kustom
  15. V8-m
    V8-m
    from Alaska
    I used oil based paint for modellers. Brush painted the contour. The colour is creamy. I wanted it to be subtle.
    teach'm and Big Al like this.
  16. landseaandair
    landseaandair
    from phoenix
    I had decent luck with a Testors paint pen but the first coat turned tan and needed a second application for it to look right.
