Technical Sending unit for exposed bed mount aluminum or stainless tank?
Discussion in 'Traditional Hot Rods' started by tlmartin84, Dec 15, 2013.
  1. tlmartin84
    tlmartin84
    from WV
    I plan to place my tank in the bed of my truck behind the cab.
    Either aluminum, stainless, or possibly painted steel with bungs welded in the sides to attach the bedsides to. Essentially being the front bed panel. I want to use a pop up filler for a nice clean look but I am not sure what to do for a sending unit.
    Any ideas? Is there anything on the market that can be hidden in the tank? Or has a really clean install???
  2. squirrel
    My guess is the tank will be so big that you won't need to worry much about fuel level very often? Should be easy to peek in to see how it's doing every now and then.
  3. metal man
    metal man
    Use a sending unit from the same manufacturer as your guages. It seems unlikely, but sometimes if you mix them up, for example use Cl***ic Instruments guages with a Stewart Warner sending unit, The guage can read incorrectly.
    If you're worried about the appearance, why not just make a simple cover for it?
  4. HOTRODPRIMER
    HOTRODPRIMER
    You can use the old fashion gas gauge,:D HRP
  5. tlmartin84
    tlmartin84
    from WV
    A cover will work but only as a last resort. I was hoping to find some type of a universal side mount unit or something similar that could be mounted between the cab and bed and out of site.
  6. Hotrodmyk
    Hotrodmyk
    Now that's cool!
  7. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
    Mooneyes makes the bungs and has the senders for their larger tanks
    take a look at their website: mooneyesusa.com
  8. go oldschool, put a bung at the top and bottom on one end with a piece of clear tube between them and make a visual gauge.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    That clear tube "gauge" would be a serious safety violation on most anyone's car.
  10. Bert Kollar
    Bert Kollar
    Just a suggestion. Here's how I mounted my Tanks Inc unit in my RPU. Completely below the deck with a traditional side filler . I will have a flat wood deck with no holes at all.
  11. dreracecar
    dreracecar
    from so-cal
    I have used these float level switches before and just a dash light. When the dash light flickers, start thinking about gas, When light stays on, look for gas.
  12. scootrz1
    scootrz1
    from usa
    not sure if it helps mine is sending unit out of a harley davidson bike to SW gage
  13. I like this idea, placed down on the side of the tank, it would be unnoticeable. I can remember running out of gas with a VW beetle, reaching over with your toe, flipping the lever and having the engine come back to life. It would only do that once though, second time you ran out, you walked! LOL
    I had a pick-up that I drove for years without a working gas gauge, I used the trip odometer and filled at 200 miles, never ran out once in all the time I had it.
  14. metal man
    metal man
    I drove my '40 for 15 years without a fuel gauge (or a speedometer ). It's had one now for about the last ten years, but I think it may be the only vehicle I have had that I never ran out of gas in.
  15. adam401
    adam401
    yardstick. don't overthink it
