Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. hershambob
    hershambob
    got this one out of socal,on its way to England!!1975 250/c4
    droppedstepside likes this.
  2. porkshop
    porkshop
    from Clovis Ca
    Mines for sale in cl***ifieds. want something else....
  3. 67econoline gasser
    67econoline gasser
    from Florida
    What springs are you using to get that lift ...and where did you get them looking to lift my Eco- pick up
  4. falconwagon62
    falconwagon62
    My E100 Christmas tree truck....
  5. PetesPonies
    PetesPonies
    from Maryland
    Looks great!! So fugly, so cool !! Now no one has a line on a '67 Econoline master cylinder do they?
  6. Hellfish
    Hellfish
    The '67 MC is very rare and you can't get a rebuild kit for it... but there are a few kits out there that will retrofit a dual MC into any Econoline.
  7. PetesPonies
    PetesPonies
    from Maryland
    I thought you can get a kit. I have seen some retro fit kits and thought they were too much money.I thought someone had plans for building a bracket to adapt another MC but can't seem to find one. Not interested in buying a $250 bracket :)
  8. butch27
    butch27
    There is a company that resleves the bore with stainless . Saw them at Hershey.
  9. Hellfish
    Hellfish
    Here's everything you need for $300
    http://www.themodernform.com/econoline/econoline_master.html
    FWIW, the last time I saw a '67 MC it went for about $300.
    I used one of Fred Carello's brackets and a '77 Maverick MC to go with my disk brakes. The bracket and MC was less than $100. I'm not sure if Fred is still making his brackets, but he sent me the plans.
  10. tubular
    tubular
    from MI
    I've been looking for another econoline van or pickup. Should not have sold mine. Anybody have a line on one? Thanks
  11. econolineherb
    econolineherb
    Hi . Check with the Econoline groups for the parts you want . There are Econolines there for sale too.
  12. bengeltiger
    bengeltiger
    Cool tailgate, lmao!
  13. 1968pickup
    1968pickup
    from ND
    Has anyone ever put or seen a yblock in a old econoline?
  14. Hellfish
    Hellfish
    They're heavy engines, right? I'm sure it could be done, but you'd probably have to make more modifications. Compare the mounts and oil pan to a 289/302 and compare dimensions. That will tell you a lot about how difficult it would be.
  15. The Mickster
    The Mickster
    Mine's not finished by any means but it does run and drive. It's a 66 model, originally from the U.S. Navy. I put a 454 Chevy with Turbo 400 in the original
    dog house, after modifying it a little. I used Corbeau seats because they were the only small seats that would fit. Comp Cams Thumpr cam, ****** Headers and Holley carb on Airgap manifold. The rear is original 9" 31 spline. Drilled the front axle with 1" holes. Using 4" blocks up front, but it's just temporary until I get the new springs built. Was original Navy issue gray inside and out. Will be 06 Hummer yellow when done. I wish now I had left the gray faded paint. Fun to play with, but not married to it by any means.
    droppedstepside and YocumBros. like this.
  16. dirttoo
    dirttoo
    WOW, I really like that. I just opened a small sign/vehicle lettering/wraps shop and I need one of these for my shop truck. Awesome!
  17. go-twichy
    go-twichy
    I've never even thought of that one. things that make you go hmmmm.
  18. Harrison
    Harrison
    I'm new to these vans and don't know Fred Carello. Do you still have the plans for that master cylinder bracket? I would ***ume that the brake pedal mounts in the bracket somehow - similar to the one on the Modern Forums site?
    I'd like to upgrade my brakes sooner than later.
    Seems like there would/should be an economical front disc swap possible too. Does anyone know of a way to swap to front discs using salvage yard or over the counter "parts store" parts?
    Thanks, Jim
  19. Hellfish
    Hellfish
    Send me you email address and I'll email the plans. It's actually pretty simple to build, but you'll need to cut a new filler access panel into the floor (or add a remote filler).
    There are plans out there for a junkyard conversion using AMC parts... but good luck finding one in a junkyard. All of the D&D parts are common parts, so all you really need is the bracket.
  20. gimpyshotrods
    gimpyshotrods
  21. mclothier3
    mclothier3
    New guy checking in, just bought a 65 5 window pickup in rough shape, looks like its been sitting several years and will need pretty much everything gone thru. Besides the mechanical's needing attention, looks like its gonna need every patch panel they make and then some, since rust never sleeps.
    Its got the 170 with the three speed on the tree, carb is missing, seller cant find the keys, etc, etc.
    I think I had blinders on when I bought it, now Ive got buyers remorse, cant decide if I wanna spend the time and money to go thru it and get it back on the road or just punt.
    Ill try to find some pics...
  22. tubular
    tubular
    from MI
    Nice van!but that's not a econoline.
  23. gimpyshotrods
    gimpyshotrods
    You can call a pig a duck, but it ain't gonna quack.
  24. slychamp
    slychamp
    from Qc ca
    i delete my last post was at the wrong place for it :eek:
    same thing happen with my grumman people call it a stepvan !!
  25. mclothier3
    mclothier3
    Ive read thru 75% of all 120+ pages of this thread and didn't see if anyone has done a three on the tree to floor shift conversion?
    The linkage on mine is pretty jankety, seems like a floor shift would work. Maybe not?
  26. saltflats
    saltflats
    from Missouri
    I have worked on some chevy vans that had factory floor shifters not very common but there may be some out there.
  27. Get creative with the cable shifter from a front wheel drive.
  28. gimpyshotrods
    gimpyshotrods
    You should be able to use two Morse push-pull cables, and some fabricated brackets. Then it could go anywhere the cable bend radius would allow.
  29. dante81_98
    dante81_98
    Made a little progress on mine. Mounted a spun aluminum tank in the bed and got the trans filled up. It's starting and moving under it's own power again. It's currently at the suspension shop to get everything in order. Looking to get another inch or so lower before we call it done.
  30. chainsaw
    chainsaw
    I think it sits real good right now. That's how I would like mine to sit.
