What is the lever for? 53 merc
Discussion in 'The Hokey Ass Message Board' started by solo_909, Dec 15, 2013.
  1. solo_909
    solo_909
    So I was replacing a fuse under the dash and found this knob that the previous owner cut out. ImageUploadedByH.A.M.B.1387136779.036001.jpg
    I opened the hood and found that it connects to this lever coming out of the firewall
    and is attached to a stronger piece. Wtf is this for?
    Thanks,
    George
  2. squirrel
    it's connected to the round can thing, isn't it?
  3. solo_909
    solo_909
    I can't tell what it's connected too
  4. paleot
    paleot
    from louisiana
    My 53 Ford had a w/s washer pump similar to that but it was mounted further down on the toe board.
    Tony
  5. solo_909
    solo_909
    Hmm, that would make sense. I do have some sort of reserve tank in the driver side inner fender but it's not hooked up to anything. I don't have a kick down switch so I know it's not OD. Thanks
  6. 56premiere
    56premiere
    Solo, I don't know what that part connected to, but if you have power brakes the tank in the fender may be the reserve for those. That how my lincolns are. Jack
  7. gatz
    gatz
    manual ch***is lube ?
  8. Lee_Ford
    Lee_Ford
    You said you did not have OD, but in 60 years of life, the Merc may have one time had OD. It looks like it would work good for that.
  9. Relic Stew
    Relic Stew
    from Wisconsin
    Does the linkage go anywhere beyond what's pictured?
    Never know what a previous owner may have added at some point.
    If you can't figure it out, just tell everyone it's the oil slick dump valve from the cars days as a moonshine runner.
  10. solo_909
    solo_909
    I'm still running stock breaks so it's not a power break reserve. There's no kick down switch under the gas peddle and no hole in the floor board for one so I don't think it's that. I'll try and get a shot of under the car soon and post it up. The lever seems to run under the driver side floor board.
  11. I see clutch linkage,,,am I wrong?
  12. solo_909
    solo_909
    The photo didn't show up. Can you try posting it again.
  13. Henry VIII
    Henry VIII
    from Tulsa OK
    It's not part of an original overdrive.
  14. leadsled
    leadsled
    mine does not have that, mine has always been an automatic
  15. raprap
    raprap
    from Ohio
    It's a hill stopper. You come to a stop on an incline, press the brakes, push the ****on, then you can take your foot off the brake and as long as you have the ****on pressed, it will hold the car. Then you can let the clutch out and lift off the ****on for a "no roll back" start on a hill.
    kind of like an old time Line Lock.
  16. Mike51Merc
    Mike51Merc
    In the interior photo, the white ****on is to the left and higher than the clutch pedal.
    In the engine compartment photo, the clutch linkage is dead center, and there's a canister with the rubber hose to the right and higher than the clutch linkage.
    Judging from the round ****on sitting in a poorly cut square hole, it looks like somebody added a windshield washer pump.
