Cow Town Coach works today in the shop
Discussion in 'The Hokey Ass Message Board' started by tbauer, Mar 9, 2013.
  1. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1386245662.239045.jpg ImageUploadedByH.A.M.B.1386245746.233092.jpg
  2. tbauer
    tbauer
    Here is my first attempt to post from an iPad and the completed fenders !
  3. Outstanding talent!
  4. Jimbo17
    Jimbo17
    Always love looking at metal work by a master craftsman and your work is in a class by itself for sure.
    Keep posting and creating works of art.
    Jimbo
  5. koolkemp
    koolkemp
    Wow great workmanship!!
  6. This looks like fun!
  7. dang....and he even knows how to post with that app ba raddis thingie...
    good work there !!!
    lwf
  8. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1386304166.913933.jpg ImageUploadedByH.A.M.B.1386304202.025187.jpg ImageUploadedByH.A.M.B.1386304226.057983.jpg ImageUploadedByH.A.M.B.1386304245.026995.jpg ImageUploadedByH.A.M.B.1386304276.582527.jpg ImageUploadedByH.A.M.B.1386304314.879403.jpg These fenders are for a 1933 auburn boat tail speedster. A v12 factory hot rod with a two speed rear axel. After making new running boards to fit reproduction rubber covers the front fenders needed to be widened to match. I shaped the bare metal pieces with an english wheel . These pieces are almost four feet long. The outside edge is wire edged to add strength. I also had to make a new flange piece where the running board bolts to the fender. The metal is 18 gauge cold rolled steel and everything is butt welded together. Tomorrow all the welds will be dressed and metal finnished, then on to the drivers side fender.
  9. 80WTI
    80WTI
    That's some fine talent you have their mate. Thanks for sharing the pics and i look forward to some more. Lee
  10. go-twichy
    go-twichy
    did you take classes for this? from who? I looks like you've got the touch.
  11. tbauer
    tbauer
    Thanks for checking out my post and the words of encouragement. I attended metal shaping class with Lazze, and bought every book and video I ran across. There is some great free info on utube also. Just get a hammer and start bashing some metal.
  12. chinarus
    chinarus
    from Georgia
    I bought some panels from a few years ago and your learning progress and talent level now is totally amazing!
  13. weps
    weps
    from auburn,IN
    were the outside edges of the Auburn fenders that bad, or did you rework them to a 'closed' style?
    I could not see enough from the side to tell.
    Awesome work for sure! As you probably know, the V12 running boards are longer than the 8 cylinder cars. and the replacement rubber is EXPEN$IVE!
  14. tbauer
    tbauer
    Hi weps, The fenders hand been modified and did not match the new running boards I made. They were too narrow and the wired edge was missing on the last four feet of the front fenders where they meet the running boards. The driver side needs new metal on the inside and outside of the fender.
    Do you have a body for your project? I would love to build a boat tail body. Ill be watching your progress. Thanks.
  15. tbauer
    tbauer
    Thanks for the kind words Chiarus !
  16. thenephilm
    thenephilm
    from cincinnati
    Everything looks great!
  17. Sundown Kid
    Sundown Kid
    Are you in Fort Worth? I need some work done, Im PMing you
  18. weps
    weps
    from auburn,IN
    well, I happen to have a 31 frame,cowl,hood and front fenders that are "extra" from my project....
    PM if interested
  19. tbauer
    tbauer
    Time to wire edge the drivers fender. First I mark the profile of the fender. Add metal to wrap around the wire. Bend metal to 90 degrees. ImageUploadedByH.A.M.B.1387050053.367931.jpg
  20. tbauer
    tbauer
    Now I've got the edge bent to a 90 so it's time to clamp the 3/16 inch ImageUploadedByH.A.M.B.1387051664.224154.jpg wire in place and work the metal over it.
  21. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1387053322.454305.jpg Here is a channel lock pliers I customized to wrap the metal around the wire
  22. Irrational Metalworks
    Alliance Vendor
    from DFW
    Wire edging is a PITA! Even worse in tight quarters. I had 72ft on the Morgan project. I was glad to be done! Looking good Ted, keep after it!
  23. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1387409253.144137.jpg heres the new inside front fender piece fabricated ,welded in and 90 percent metal finished
  24. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1387409392.881163.jpg a view from the running board
  25. tbauer
    tbauer
  26. tbauer
    tbauer
    Here are the running boards I made that started the whole job ImageUploadedByH.A.M.B.1387409659.600983.jpg
  27. 60 Belair
    60 Belair
    Wow nice metal work
  28. tbauer
    tbauer
    Today's metal work is a 35/36 roadster dash, no problem ! With glove box , maybe a little problem.
    First I made the door with wire edge and hinge ImageUploadedByH.A.M.B.1388107722.577831.jpg ImageUploadedByH.A.M.B.1388107742.169823.jpg
    Then I counter sunk the hole so the door sits flush ImageUploadedByH.A.M.B.1388107820.756817.jpg
    Then I bent the inside flange for the cardboard glove box too attach to ImageUploadedByH.A.M.B.1388107903.950317.jpg next it's time to lay out the dash from a paper pattern ImageUploadedByH.A.M.B.1388107955.029845.jpg
    I cut the dash out and turned the flange across the top to the angle as the original ImageUploadedByH.A.M.B.1388108044.298454.jpg ImageUploadedByH.A.M.B.1388108056.619160.jpg
    More to come...
  29. tbauer
    tbauer
    Here the dash so far
  30. Squablow
    Squablow
    Impressive metal working skills, keep posting.
