1940 Ford Recessed firewall
Discussion in 'The Hokey Ass Message Board' started by Fopelaez, Dec 18, 2013.
  1. Fopelaez
    Fopelaez
    I did the search function and very little options showed up. I'm planning to buy a 5 in recessed firewall for my 1940 ford coupe. I initially thought of buying from Bob Drake but it has been out of stock for a while now, besides its a bit pricey.
    I found these options for firewall and floor sections and I wonder if anyone have bought from these guys, they seem ok and feedback is fair, opinions please.
    http://www.ebay.com/itm/Ford-Front-...Parts_Accessories&vxp=mtr&hash=item3f22c571dc
    http://cgi.ebay.com/ws/eBayISAPI.dl...akeTrack=true&ssPageName=VIP:watchlink:top:en
    Of course I'm looking for options with the best quality/fit and looks. Any guidance will be very much appreciated.
    Fernando
  2. flamedabone
    flamedabone
    Do you definitely need that much recess? What engine are you useing?
    -Abone
  3. richie rebel
    richie rebel
    *****in firewalls...........
  4. richie rebel
    richie rebel
    5 inchs really?????
  5. Fopelaez
    Fopelaez
    Initially I thought of using a 3 in recess only, but comments from a friend (who has built several coupes) told me I'd be better off with a 5 in recess. My plans are to run a supercharged SBF (still to be defined due to supercharger availability for Fords). I'm
    kind of following the advise of someone with more experience.
    Same price for 3 in or 5 in though. I'm more concerned about fit quality.
    I'll take a look at *****n fw.
  6. Pewsplace
    Pewsplace
    *****en is no longer in business. You really don't need a 5 inch recess unless you are running a big set-back for the blower drive. A large set-back requires major frame modifications but that is not hard. Leg room is what you should be concerned with that much (5") set-back. Try direct sheetmetall for a firewall.
  7. 40Standard
    40Standard
    from Indy
    if you run a SBC, you can use your stock firewall
  8. chadhollem
    chadhollem
    I put a ems in my 40 coupe fit was good instructions were easy mine is 3 inch set back also put there floor in it
  9. Fopelaez
    Fopelaez
    Thanks for the comments, I'll try to see if I can get into a car with a 5 in set back, I'm not too tall LOL but definitely something to consider, besides my truck, which has plenty of engine room, this is the first 40's project I tackle. Thanks guys.
  10. 4tford
    4tford
    For what it is worth my 40 has the 5 inch and I have a 392 hemi which is pretty big front to back and there is plenty of room probably could have used a 3 inch for more leg room. I'll post a few pics for you.
  11. NATESBPD
    NATESBPD
    This is my 4" from direct sheet metal..I got it fast and great guys to talk to on phone...my 40 has a 302.
  12. NATESBPD
    NATESBPD
    I also used their floor....
  13. Fopelaez
    Fopelaez
    Thanks 4t and Nate I appreciate the pics, maybe 4 in is a good compromise.
  14. sawzall
    sawzall
    1940 ford coupe.. stock firewall.. 302 ford with AOD..
    note that the center of the firewall is wider.. no need for any aftermarket smooth firewalls..
  15. go-twichy
    go-twichy
    i'm putting that same 302/aod in my 40 coupe. do you think it was totaly nessesary to widen the middle section like that? i'm not quite ready to drop the body back on and start checking out clearences yet. i'm still re-installing a stock 40 firewall because someone before me hacked the stock on out.
  16. Build yer own...
  17. NATESBPD
    NATESBPD
    The 302 with Aod does fit with the stock firewall...here is a few pics with mock up motor...just wanted a little room.
  18. street rod lover
    street rod lover
    from taylor,mi.
    just recessed my 40 sedan for a sbf. used a piece of sheetmetal and formed my owned. fit well against new ems floor kit.
