Customs 51 mercury
Discussion in 'The Hokey Ass Message Board' started by choptvan, Jul 12, 2013.
  1. choptvan
    choptvan
    Those seats wont match the rear seat. The wrap around 64 t bird seat. Any bigger and they would be taller than the rear seat. Then they really would look out of place. The drivers seat is a power seat. I am just over 5ft 5in tall. The owner is over 6ft. For this to work with both of us, this was an easy answer and still a match to the rear seat. As for the frenching. Yeah. I am aware. Dont want it to look out of place. I have replaced 50% of this car due to rust. Dont want to mess it ip with the headlights. Thanks.
  2. Bad Bob
    Bad Bob
    from O.C. Baby
    Looks like a nice build. Looking forward to seeing it when it's done.
  3. choptvan
    choptvan
    Thanks bob! Comin from you, that means a lot!
  4. Mercman4life
    Mercman4life
    Looks great . Keep posting. But I love merc's .
  5. DjNeil
    DjNeil
    What are your thoughts on the fatman front stub. I presume not possible to install with the front sheet metal still in place.
  6. choptvan
    choptvan
    Went real well. To do it right, you will have to remove the sheet metal. Not at all possible with the front clip on it
  7. DjNeil
    DjNeil
    I thought that would be the case.
    How much of a drop did you get and did you re use the original steering column
    thanks
  8. choptvan
    choptvan
    We decided to use a NON tilt gm type column. Looked better overall that way. Doesnt look 80's that way! And so far so good.
  9. TJratz
    TJratz
    1/4 panels wellded up or still stock bolt on?
  10. choptvan
    choptvan
    Welded up. We wanted to keep it smooth like the door. With the line it seemed broken up. We wanted it to flow all the way back. Its welded to the rocker as well and we are thinking about molding the front clip for the same reasons.
  11. straykatkustoms
    straykatkustoms
    I love the front wheel wells, very Kool project. Keep us posted with the progress.
  12. choptvan
    choptvan
    Will do! The next step is under the hood. Custom fender wells and air cleaner system of some kind. Finish the firewall too. But we are still waiting on our wheels so once those come in, there will some serious progress. Thanks!
  13. choptvan
    choptvan
    Coker's new h78 15's. cant wait to set it on the ground!
  14. choptvan
    choptvan
  15. Very nice, subscribing.
  16. choptvan
    choptvan
    Thanks. More progress photos soon
  17. choptvan
    choptvan
    Some updates on the merc. Some is a bit OT for the site. So that has been omitted
  18. Bad Bob
    Bad Bob
    from O.C. Baby
    Now that my new computer is working,I went back and looked at the pic's. Love the outside! My only thing is,the consol. Too tall,too wide,too square! Doesn't flow to me. Rounder maybe? Sloped down toward the back? IMO...
  19. jfreakofkorn
    jfreakofkorn
  20. wicarnut
    wicarnut
    VERY KOOL! NICE WORK! Admire your skills. John
  21. 40FORDPU
    40FORDPU
    Looking good so far.
    I really like the '53 Desoto grille teeth on these.
    Will you be rounding the hood corners?
    Thanks for the updates, keep us posted.
  22. choptvan
    choptvan
    Thanks bob. Once you see the rest of the metal work that will happen inside, you will see how it all goes together. Hard for me to explain what is in my head!
  23. choptvan
    choptvan
    Not on this one. With the sharp corners in the windows and door frames, it wouldnt make sense. Thanks a lot! Love hearing opinions. Good and bad
  24. choptvan
    choptvan
    Have gotten quite a bit done it recently. Brought the bumper in 1 3/8", molded in the factory tail lights, eliminated some of the bumper bracket and brought the exhaust through the bumper, continuing on the chop just have the p*** side quarter window to finish then sand and grind the chop down and m***age it where necessary. Starting on the flush mount skirts soon as well.
  25. desotot
    desotot
    Looking good, I'll be watching.
  26. Looking Good but I am Predugest to 49 thru 51 Merc's
    Keep up the Good Work
    Just my 3.5 cents
  27. choptvan
    choptvan
    Thanks guys. Starting to shape skirts
    Used some 54 front fender lips like on the front, and are shaping those to fit
  28. I am going to put a Mustang Floor Shifter in my Merc when the Weather Permits
    it mounts on the Floor not the ******
    Just rite for my Powerglide
    Just my 3.5 cents
  29. choptvan
    choptvan
    We used a floor mount lokar for the 700r4
  30. the Mustang shifter came out of a Mid 60's car & it was Free
    and you can't be that & its Sharp looking the Shaft & handle are Chrome
    with the Pattern on the Floor with a Light
    It will look Good
    Just my 3.5 cents
