Projects 1928 Sedan, what would you do..... photoshop help please?
Discussion in 'Traditional Hot Rods' started by BAILEIGH INC, Dec 13, 2013.
  1. bonustoolkit
    bonustoolkit
  2. Hitchhiker
    Hitchhiker
    Gonna have a hard time getting it that low in the back without major surgery.
  3. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Thats OK, a little higher in the back would look good i think.
  4. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Thanks guys, this is fun. I have all winter to dial it in. :cool:
  5. master85
    master85
    from TEXAS
    That is an awesome example. Please dont chop it!
  6. J'st Wandering
    J'st Wandering
    I think that the Model A brake drums will be a problem for 16" solid rims. The 16 inch wires will work. If you go to hydraulic brakes, you will switch out the drums. Someone will clarify this I am sure.
    Neal
  7. Solid rims with stock model A mechanical brake drums is definitely a BIG PROBLEM. The solution is to grind down the raised are on the drums (which I hate to do) or get an adapter ring. The problem can be seen at: http://www.jalopyjournal.com/forum/showthread.php?p=8330045&highlight=stephens#post8330045
    Charlie Stephens
  8. A Boner
    A Boner
    X2 .....just keep off the freeway!
  9. cody1958
    cody1958
    from wichita ks
    Yah what this guy said.
  10. Hitchhiker
    Hitchhiker
    Why? My A does freeway speeds.
  11. bubblesbacon
    bubblesbacon
    from wisconsin
    CHOPP IT!!! :eek:
  12. Bader 2
    Bader 2
    Yeah, i know it's not a sedan but,Borg Warner torque tube over drive,411 gears,juice brakes,in the middle of an insert, full pressure, insert, counterbalanced 7 to 1 compression banger.35 wires,7.50 and 600 16 reverse front eyes, mod spring back nothing irreversible! Lots of fun! 70 mph with basically stock motor. Was cheap and easy, xcept engine,and some time spent. Get it to sit right,and pick away while you drive it! Congratulations. A *****s coupe is awesome too!
  13. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Big thanks to D-Russ!
    Bam!
  14. 3spd
    3spd
    Now that is some good Photoshopping D-Russ. I don't have the skills to 'shop that well or the patience to get the skill!
    Ryland
  15. Dean Lowe
    Dean Lowe
    This is perfect.
    The chop, no!
  16. lakeroadster
    lakeroadster
    from *
    x3... no whitewalls and no chop. Henry did a fine job on these.
  17. madpole
    madpole
    nice car! i like the look of the car. paint scheme etc. i would pull off the bumpers, ahooga, put on some 16" wires and find a few old speed parts for the banger.
  18. T&A Flathead
    T&A Flathead
    ^^^^ perfect ^^^^^
  19. T&A Flathead
    T&A Flathead
    This is what I meant......perfect.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Perfection..personified..period~ HRP
  21. Okie Pete
    Okie Pete
    ^ That's it right there no chop.
  22. The37Kid
    The37Kid
    This is the perfect 28-29 Ford look to me, the 16" wheeld fit the front fenders perfectly. Hot Rods without hoods look broken to me. Bob [​IMG]
  23. OahuEli
    OahuEli
    from Hawaii
    Yup, maybe with artillery wheels though.
  24. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Nice look
  25. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I'm thinking brakes and wheels to get started.
  26. A Rodder
    A Rodder
    I may be wrong, but with the color of the car, you can't go to extreme with anything.
    Fenders, unchopped is where it needs to stay. Tires and wheels, stance is probably the only thing you really can do to it.
    I heard about that car from Bill & Matt asking what I thought about it. I think it was a killer deal.
    I think it is one of those that you do what you have in mind, anything more and you might as well go all in and make it bad ***, thus ruining what you have.
    I have only sold one A out of 15 because it was too nice. I regret it still that I didn't just do a few simple details. I am still in contact with the owner and am trying to work a deal to get it back.
    This car definately falls in the keep it simple catagory looks wise.
    BUT hop that banger up and make it go 55......and get there waaaay quicker.
    The other thing I would do is really consider the Clings adapter and put in a V8 trans.
    In driving my banger A's, the motor is not a hindrence to me, it is the ******** trans and the ****py gear splits,(which is compounded by the taller tires). All I had to do is drive my Flathead 39 boxed roadster one time to know that I don't think I will do another banger A for myself and keep the stock trans.
    Go pick up some chicks!
  27. cheesegrater
    cheesegrater
    from california
    If you plan on going any distances with it out on the freeways upgrade the brakes (Might be cheaper to do discs than old ones )& buy an overdrive unit for it if only for a parade or in town "LEAVE HER ALONE"
  28. 05snopro440
    05snopro440
    I respectfully disagree on the colour limiting things. I've seen two full blown chopped and channelled fenderless A's in that colour combo. Both looked killer. That said, this car shouldn't go that way.
  29. A Rodder
    A Rodder
    No problem at all, do you have pics of the others? It might help someone else in deciding which way to go.
    I think you, I, and Shane all agree, on this car the less major changes, the better.
  30. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    x2 :cool:
