Features Vintage Multiple Carb Intake Pictures
Discussion in 'Traditional Hot Rods' started by PKap, Feb 9, 2013.
  1. Paul
    Paul
    Editor
    bringing it back up
    enloe likes this.
  2. 64cummins
    64cummins
    from kansas
    ImageUploadedByH.A.M.B.1386567838.090224.jpg a little 10.5to 1 223 with clay smith cam barker hi lifters Fenton valve cover and intake and 3 1957 holley gl*** bowl carbs
  3. kuhn1941
    kuhn1941
    This is my 1941 buick straight 8 (248ci) factory set up that I just removed to build my own 4 holley 94 set up with headers .
  4. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    Scotty eight tops
  5. 392modela
    392modela
  6. 392modela
    392modela
    Here's mine
  7. 1934calkid
    1934calkid
    Here is mine .....
  8. seb fontana
    seb fontana
    from ct
    Couple/four not too common..
  9. seb fontana
    seb fontana
    from ct
  10. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    What is that last intake? what kind of carbs does it use? Really cool!!
  11. 1948plymouth
    1948plymouth
    from Minnesota
    Looks like small block Ford to me. But I'm a Mopar guy, so what do I know.
  12. Mat Thrasher
    Mat Thrasher
    Bad ***! Are you casing these?
  13. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    No I found the guy that made them and buying all of the castings.
  14. Mat Thrasher
    Mat Thrasher
    I think you're set for life for multi carb blower projects!
  15. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    I have three friends building blown multi carb model A's.I'm trying to bring this culture to the west coast of Florida, one hot rod at a time.
  16. Mat Thrasher
    Mat Thrasher
    Your influence must be spreading to NE Ohio too. ImageUploadedByH.A.M.B.1387591048.935059.jpg ImageUploadedByH.A.M.B.1387591079.600245.jpg
    ls1yj likes this.
  17. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    Matt that looks awsome, I didn't know it was almost done.
  18. Kirk Hanning
    Kirk Hanning
    Here's a 241" Dodge
    ls1yj likes this.
  19. Kirk Hanning
    Kirk Hanning
    A 354" dining room piece at the moment
    ls1yj likes this.
  20. snopeks garage
    snopeks garage
    from macomb MI
    Here's mine that ****ster brought back to life
  21. PKap
    PKap
    from Alberta
    I love that fuel rail, one of the nicest I have seen, definitely going to do something similar on mine
  22. langy
    langy
    My 6 x 94's on Drag Star log on 394 Olds
  23. 1948plymouth
    1948plymouth
    from Minnesota
    I like what you did with the fuel lines.
  24. seb fontana
    seb fontana
    from ct
    Last manifold [bottom right] is for a Boss 302 [69/70] and will take typical 4150/4160 carbs, probably was a consideration for trans am racing..
  25. gale
    gale
    from colorado
    here is mine
  26. gale
    gale
    from colorado
    one more
  27. 392modela
    392modela
    Are there any more out there
    posted with a box of crayons on the outhouse wall
  28. 1948plymouth
    1948plymouth
    from Minnesota
    Great thread for ideas. I just got a handful of Heims joints. I built a 3 pack (3-1bbl) for the flathead in my 48 Plymouth. Now I can build the linkages to make them work. I'll post a pick when done.
  29. GlassThamesDoug
    GlassThamesDoug
    I like to run the 2BBL Holley's. Twin 500's on 292 cu in working with good RPM, and good response. Twin 650's will be for larger cubic inch.
  30. sailingadventure
    sailingadventure
    Here`s a picture of my V-8 60 with 2 81`s.
    [​IMG][​IMG]
