Projects What to do with this body
Discussion in 'The Hokey Ass Message Board' started by Slake43, Dec 24, 2013.
  1. Slake43
    Slake43
    from Melton
    ImageUploadedByH.A.M.B.1387871739.135859.jpg . Thinking hi boy style artillary rims , channelled with flathead , original suspension etc !
  2. Slake43
    Slake43
    from Melton
  3. Exactly like this. An "original" look, but a fair bit lowered. This thing is perfect. Would also run all the original running gear, and i'd put it on a sedan ch***is to do away with parallel leaf springs because i probably wouldn't be putting much in it anyway.
    <iframe src="http://www.flickr.com/photos/daddio/8543346318/in/photostream/player/" width="500" height="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
  4. Slake43
    Slake43
    from Melton
    Yeah I have been looking for a sedan ch***is , seem hard to find in victoria. It would look very nice as a fendered pickup .
  5. Slake43
    Slake43
    from Melton
    ImageUploadedByH.A.M.B.1387883233.463659.jpg the body has these front panels originally it was a 1 1/2 ton truck of 1940 vintage , the body though is the triple body line the same as the US 1938 model ford. I'm not sure how these came to be . A mixed bag of surplus body's from the US maybe ?
  6. Slake43
    Slake43
    from Melton
    He he , a shameless plug indeed ! Nice ch***is though ,
  7. junkman8888
    junkman8888
    Greetings! Three ribs on the doors means it's a '38. Am still wondering how you are going to build a "channeled highboy".
  8. charlieb66
    charlieb66
    First thing you should do is make sure you can get it ***led and registered before you spend money and time on it. What is the "arm" mounted on the door, it appears to be a signal device of some sort?
  9. low budget
    low budget
    from Central Ky
    Well at least you can throw fire wood in the bed (when you get one) and not worry about a stick going through the back gl***:D
  10. ram-rod
    ram-rod
    Yes a signalling device, if you hauled in on the lever you got a turn signal and if you pulled on the knob the metal hand turned up-right for stop position.
    it was a bit tricky with a stick shift, double clutching and worn steering box
    fully loaded coming up to an intersection
    Made even worse if the window was up
  11. I was wondering that myself, maybe he'll post a build thread!:eek:
  12. Stevie Nash
    Stevie Nash
    I'm digging the jail bars on the back window!
  13. Damn I was thinking wide load mirrors in the swing stowed position.
  14. cryptkepper
    cryptkepper
    from louisanna
    All of the above except Chop section and channel over a custom made "Z'ed Frame!
  15. Hnstray
    Hnstray
    from Quincy, IL
    The '38 style body lines DO NOT mean it's a '38. It means the panels were stamped from dies originally used on US production '38 models. The US makers often used previous year (by then obsolete) dies for vehicles produced in other Countries. It was driven by economics, and nothing more.
    Look at '50s and '60s Aussie Chrysler products for a good example of this.
  16. 56don
    56don
    Unless you can find the rest of it, I am thinking rat rod.
  17. swade41
    swade41
    from Buffalo,NY
    this would be my choice
  18. adam401
    adam401
    Take all the ideas from your original post (flathead, artillery wheels) and apply them to a couple or roadster. you will put the same effort in and have a more legit ride.
    The term highboy refers to hot rod that is not channeled.
  19. 302GMC
    302GMC
    from Idaho
    How did the doors get those vent windows ?
  20. Slake43
    Slake43
    from Melton
    Yes junkman & 1st grumpy , have to watch my terminology here . By highboy I meant fenderless , and I know in accurate terms it's a contradiction of traditional hotroding :) . Fenderless channelled is what I mean !
  21. Slake43
    Slake43
    from Melton
    302gmc it's an Aussie vehicle !
  22. Slake43
    Slake43
    from Melton
    Thanks for the input to all of you guys and furthering my education in hotrod !
  23. There's not much to work with there to complete something like 28A pictured. Personally, if it were mine, I'd sell off the hood, chop the cab, set it on a ch***is and build a fenderless open-engined pickup rod, similar to what Anthony posted.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Start gathering parts and build a full fendered truck. HRP
  25. I agree with HRP.
    Full fendered truck would be awesome. Don't rat rod that thing.. we don't have many of those cabs left in Aus, so don't **** it up!
    How can you not like the truck in the pic i posted? Thing is perfect.
  26. toucan
    toucan
    from sc
    full fendered truck please!
  27. Ned Ludd
    Ned Ludd
    Another vote for a full-fendered truck.
    Two inspirational words if you're prone to thinking into more unusual territory, though: Marmon Herrington.
