Technical Model A fenders... anyone ever made quick offs?
Discussion in 'Traditional Hot Rods' started by chopo, Dec 24, 2013.
  1. chopo
    chopo
    I was thinking about this. one week i like the look of A's with fenders and a month later not so much. has anyone ever trimmed back there front fender and running board flanges. made the running board brackets unbolt from the frame? I really dont want to unbolt and move body around to change the look of things, just a thought. any input?
  2. Bader 2
    Bader 2
    Why, don't like the graceful look of fenders?
  3. chopo
    chopo
    i like both looks. just thinking of a way to swap around quickly.
  4. mike bowling
    mike bowling
    If you can think it, you can do it. Maybe a series of nuts flush welded to frame rails with a bracket system on fenders so you could bolt them on, or take them off and put the bolts back in the holes to cover them up???Good luck; post pics. Mike from M***. :cool:
  5. timwhit
    timwhit
    Could you slot the holes in the aprons so they slide out from under the body? Then just un-bolt everything else.....
  6. go-twichy
    go-twichy
  7. charlieb66
    charlieb66
    Just find another coupe, paint both the same color, one with and one without fenders, don't tell anyone what you are doing, use the same tag and insurance for both and drive the cruise in guys crazy.
  8. Phil Stevens
    Phil Stevens
    that's one way for sure
  9. flthd31
    flthd31
    How about something like this? An in between look with bobbed fenders that can be easily removed?
    Your chop looks great. I think you would be less likely to want fenders if you lowered the suspension a few inches.
  10. orphan auto
    orphan auto
    maybe zeus fittings?
  11. gnichols
    gnichols
    from Tampa, FL
    Unbolting the aprons just for fun would be a pain, and probably why you see old pix of so many fender-less hot rods running aprons on the lakes. The fenders would be easy to screw back on before going home and you wouldn't have to loosen the body mounting bolts to get the aprons out (slotted holes in the aprons would be handy).
    I've been considering Dzus fasteners for modified rear fenders (cycle style on the front?) on my A build for the same reason, but there would be no aprons to fool with. I was thinking that if I mounted the fasteners on the inside edge of the wheel well, I could not only use them to easily remount the fenders, but perhaps cover the wells with some sort of skirts to smooth them out, too, like skirts on a custom, when the fenders were off. So little time... Gary.
  12. chopo
    chopo
    did it... slotted aprons... bolted on running board brackets. 13 bolts per side. comes off in one unit.
    its been a year to date from start
  13. rottenleonard
    rottenleonard
    Cool, How long does it take to get them off and on?
  14. Atwater Mike
    Atwater Mike
    I like that... The "QUICK-CHANGE COUPE"!
  15. tfeverfred
    tfeverfred
    I think the whole car needs to be lowered a little.
  16. chopo
    chopo
    car will drop 3 more inches when funds are available. it takes 10 minutes per side to remove.
  17. redzoro
    redzoro
    from Elkton fl
    post #9 has the headers I want to build for my sbc powered 31 coupe ... love em !!! I thought about doing full fenders and tucking those under body where aprons go , I think it'd be cool .
  18. nooch
    nooch
    I thought about doing something like this too - the issue becomes what to do with the headlights, you'd need a different mounting system that you can switch to which probably eats into the swap time. Still pretty cool though, can you give more detail on how you did it? Any photos?
  19. luke13
    luke13
    fab up some ***y little headlight stalks that mount to the inside of the ch***is rails behind the grill.
  20. hotrodderhaag
    hotrodderhaag
    love this car! and your only an hour north of me, somehow ive never seen it!
