COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. 1carguy
    1carguy
    from Belton, KY
    Yes - I don't remember if I had it in primer then.
  2. spankster
    spankster
    Hey 1carguy. Are those Thadds trucks down in Georgia? If so pm me his number. I've lost it. Thanks
  3. 1carguy
    1carguy
    from Belton, KY
    No they are not.
  4. spankster
    spankster
    O.K. Thought that might have been him. He also lives in Georgia, & is always going out West picking up COE's .
  5. wessssay
    wessssay
    Looking for a set of doors n driver fender for my 54 chevy coe anyone got some real nice ones let me know! Thanks guys!
  6. spankster
    spankster
    wessssay, where you located, in N.C. ?
  7. wessssay
    wessssay
    North Wilkesboro, just on the other side of Winston Salem from you if ur in Burlington!
  8. spankster
    spankster
    Yep, I'm in Burlington, right off the interstate. Is that your truck, in your avatar ? What are your plans for it, if that's it ? I did know of a '54 GMC COE up your way.
  9. wessssay
    wessssay
    Yupp its mine had it for probobly 6 or 7 maybe 8 years but just really started workin on it earlier in the summer. What u know of one around here mines the only one I know of other than a guy here in town has a 55 ford coe custom. As for my plans itll be a flat bed unless I can talk a buddy of mine out of a wrecker he has then id put the wrecker set up on it but itll be ridin low it is pretty much lowered like 18 to 20 inches from its original hight just putting it on the 88 frame
  10. spankster
    spankster
    Dude offered to sell me this one in the Yadkinville area last year. 012_16A.JPG
  11. Just wondering if anyone has any shots of a late 40's early 50's Chevy COE with an extended cab. I've seen several crew cabs but can't rememer ever seeing just an extended cab, and I was wondering if there is a reason why no one has built one.
    I have a chance to pick up a 48 Chevy COE with a beat up roof and back panel. I have a 48 regular 1 1/2 ton truck with a good cab that I could use to make an extended cab, and could use some ideas. I read somewhere on the internet that the truck cabs are the same as a COE cab, but can't believe that considering the wheel wells on the COE, but I would think the rear panel and roof should be the same.
  12. spankster
    spankster
    There were no Factory conversion extended cabs, from info. I've had through the years. Only Factory conversion three door, & four door cabs, along with Factory conversion Sleeper cabs. I recently purchased a '47-'53 Factory conversion Sleeper cab. 78120896173_sleepercab-1_zps23b4e4c3.jpg
  13. I'm not looking for factory, but have seen many COE's with the cabs extended, but don't recall ever seeing a late 40's Chevy. I thought about a sleeper, but think I will go with a pick-up style bed, so the sleeper would be out of place. If I came across a factory sleeper, I would have to go with it though, and put a different style bed on the truck.
  14. spankster
    spankster
    Yeah, this was available as a Factory conversion. A regular pickup donor cab could be used to extend a COE cab. 1954-Crew-Cab.jpg
  15. Auto Doug
    Auto Doug
    i've seen this one setting in Wyoming off I-80 where the trailer? #1220
  16. phat rat
    phat rat
    You are correct rear panel and roof are the same. The lower cowl, doors and floor are different
  17. 1carguy
    1carguy
    from Belton, KY
    I want to make a 4-door out of my 1955 Chevy LCF and run some kind of diesel with an automatic. Can anyone point me to a link/forum or anything else about someone who has done the 2-door to a 4-door conversion on an LCF? Since both the front and rear door post slant forward, I think will make it a little more of a challenge.
  18.
  19. HJmaniac
    HJmaniac
  20. Try this one for starters.
    http://www.jalopyjournal.com/forum/album.php?albumid=29896
    And another one. http://ozcoetrucks.freewebhosts.com.au/index.3b.html
    Be careful checking out these links, there is enough information on them to make your head explode! LOL
  21. b-bop
    b-bop
    If only I had a little more metal working talent........
    neverdun likes this.
  22. kscarguy
    kscarguy
    I bet you wouldn't drag the fuel tank on the ground.
  23. RMR&C
    RMR&C
    from NW Montana
    A magic wand would be more useful. Neat idea, but the scale (size) would be tough to pull off.
  24. OahuEli
    OahuEli
    from Hawaii
    Pretty cool concept. I agree on the scale though, the body of the truck would need to be largely hand formed to maintain the Caddy lines,especially on the fenders and fins. As for turning radius I'm guessing it would be about the same as a school bus. Very doable for someone with deep pockets. A '59 Caddy COE ramp truck, can't get any cooler than that!
  25. Anyone got a Caddy they want to see get cut up? I can toss my Autocar sheet metal and put this on my ch***is. Oh Wait, I've only got about 20 years left to work on it, maybe I shouldn't start over on a new project.
  26. smack1984
    smack1984
    was in the mood to do a little Photochoppin I know its not good. [​IMG]
  27. phat rat
    phat rat
    I prefer the cab in the first version
  28. moparmuscle1
    moparmuscle1
    If you build it , they will come
  29. 1carguy
    1carguy
    from Belton, KY
    Thanks for the links. The first one had some photos in it I haven't seen before. The second link I have visited many times, in fact, if you look at the bottom of Page 2, there are photos of my 1938 Ford COE I did years ago. I was living in Niceville, FL then, but since have moved to KY.
  30. Bob, I checked out your 38 build, would you use the Dakota ch***is again and how did that steering system work out?
    The ch***is I'm using for my build is from a fire truck I bought from the White Plains Kentucky fire dept.
