Projects '24 T Roadster build
Discussion in 'Traditional Hot Rods' started by Anderson, Aug 21, 2012.
  1. PINEAPPLE
    PINEAPPLE
    Great stance! cool to see it outside. You nailed it. Love the machining pics..
    Matt.
  2. 26 T Ford RPU
    26 T Ford RPU
    Just a damn fine job overall. JW
  3. Great proportions!
  4. Elrod
    Elrod
    Just in time for that bead roller to arrive. :)
  5. Slake43
    Slake43
    from Melton
    Looking good Anderson !
  6. v8juice
    v8juice
  7. daddio211
    daddio211
    We can't talk you into a dual MC, can we?
  8. daddio211
    daddio211
    Do eeet mang.
    My '27 T Roadster build: www.jalopyjournal.com/forum/showthread.php?t= 734383
  9. TexasSpeed
    TexasSpeed
    from Texas
    Hmm.. I actually picked up a set of F1 pedals earlier at a swap meet for cheap. I've been debating whether I want to run those or not. Your T is motivating me to..
  10. Elrod
    Elrod
    I think a dual MC would be great peace of mind. that or actually getting the Emerg. brakes working. :eek:
  11. Dreddybear
    Dreddybear
    Are you in Austin now?
  12. Dreddybear
    Dreddybear
    Awesome. I live over at the end of Slaughter past Mopac. We gotta hang out sometime.
  13. cracker head
    cracker head
    Dreddy, be careful. All Eric wants to do is drink shiner and work on hotrods....... ;)
  14. Love is a beautiful thing......:rolleyes:
  15. He ain't the only one!
  16. cracker head
    cracker head
    Q.E. you have to shorten the pedals??
  17. Rusty
    Rusty
    Looking good Eric!
  18. Dreddybear
    Dreddybear
    La Mancha tomorrow. I will be there a little after 11 since the Chargers play at noon and since they're in the playoffs I'll be drinking to calm my nerves.
  19. Luv those brakes! Boss roadster!
  20. Dreddybear
    Dreddybear
    Right on!
  21. dwollam
    dwollam
    Wow! I don't get in here much, but I saw this and had to read all the way through. You Sir, are a craftsman! Your ideas are top notch! I put my cars together and make them work but your fabrications are works of art. Keep up the good work.
    Dave
  22. pasadenahotrod
    pasadenahotrod
    from Texas
    If the spring is mounted in tension like the factory 28-41 Ford install there will be negligable side sway. In 42 Ford started mounting the spring in big rubber bushings and using a Panhard front and rear due to the sidesway issue.
  23. Koz
    Koz
    These days virtually everyone uses the "poly" shackle bushings which are very stiff as far as sides sway goes. I occasionally use original style forged shackles but use the poly bushings. I do know more than one '46-'48 Ford with some serious handling issues due to shot shackle rubbers. Good info!
  24. Pete
    Pete
    I want this car!!!!
    Awesome!
    Pete-
  25. Elrod
    Elrod
    Pedals look clean!
  26. gwhite
    gwhite
    SUPER MODERATOR
    Sweet baby Jesus...wow!
  27. draider
    draider
    from Texas
    Sweet. That quick change looks right at home tucked up there.
  28. Six Ball
    Six Ball
    from Nevada
    Everybody is going to be checking out your rear end and they will like it. The whole back end treatment is great.
  29. LSGUN
    LSGUN
    from TX
    Looks sweet with those '41 caps.
