New regulator not working properly. Can I fix it? What brand is it?
Discussion in 'The Hokey Ass Message Board' started by DetroitDetomaso, Dec 27, 2013.
  1. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
    This regulator was installed before I bought my Merc. It works on and off. Can I fix it? If not does anyone know the brand? I would like to install a new one in the same holes.
    Any help is appreciated. I've never messed with a regulator before.
  2. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
  3. jetnow1
    jetnow1
    from CT
    Looks like a standard ford regulator- take to a decent parts house and they should be able to match it.
  4. Mr48chev
    I'm thinking that it is on one of his Cadillacs rather than a Ford.
    DD are the contact points in the regulator clean and free of burned (arced) spots?
    Almost all of the old Motor manuals from the early 60's back had a section on adjusting those regulators and other generator regulators and This Delco pfd might give you some info.
    http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
  5. I didn't even get a year out of my voltage regulator in my 56 buick wagon and got it thru Nappa auto parts .Got one on e bay for $22. and have had no problems .Stuff happens. Bruce.
  6. rotorwrench
    rotorwrench
    If a person is going to bother to repair a problematic late one, they would be better off repairing a vintage OEM or quality aftermarket one from 30 or 40 year ago on back to date of manufacture. The late ones are definitely not as repairable as the originals are.
  7. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
    Sorry I should have said it was on my Merc.
    I've been though 3 regulators now and rebuilt the generator. I'm banging my head.
  8. Can you buy an electronic version of the "points" type regulator? you could install it in the old blue housing, and having no moving parts, would be less troublesome.
  9. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
    Maybe. That might be next.
  10. brokenspoke
    brokenspoke
    I remember having to polarize ......????
  11. DetroitDetomaso
    DetroitDetomaso
    from Las Vegas
    A friend of mine and good mechanic took the generator apart. Looks like something inside the 2 twice rebuilt generator is broke. I will update with photos when I get them.
  12. oldrelics
    oldrelics
    from Calgary
    Just got the same one and its **** too. I had to dig an old one out and used it.
  13. Rocky
    Rocky
    Classified Editor
    Not saying this is what's wrong with your car but this happened to me: I was 17 and drove a 56 olds. Regulator went bad and I replace it and polarized it..worked great for about a week...generator went bad. Replaced it and everything was fine...for about 2 weeks when the new regulator stopped working again. I couldn't figure it out and before it was over I'd gone through 4 new regulators and several generators. I grew to hate the car and after buying a super cherry 50 ford with no motor, I yanked the olds motor to put it in the ford car.
    That's when I found the reason for all my Olds electrical problems. The hot wire that fed my fuse panel went through the firewall and was supposed to be encased in a rubber grommet that was missing. The hot wire would occasionally contact the sharp edge of the firewall hole, grounding out momentarily, taking out my generator or/and regulator.
    The 245 HP olds worked grat in the little shubox but was hell on 3 speed ******s.
