Stock 1932 steering box location?
Discussion in 'The Hokey Ass Message Board' started by el Scotto, May 8, 2013.
  1. el Scotto
    el Scotto
    from Tracy, CA
    I've been searching for over an hour now and I can't find the thread. I know it's on here. I've tried multiple terms, I even used Google. I'm beginning to feel a little stupid now, especially since I was able to find it the last time I searched for it.
    Does anyone have the measurements for the location of the stock steering box hole on a 1932 Ford frame?
    Thanks guys... :p
  2. Baron
    Baron
    If you can't make it out from this I can measure my frame tomorrow when I get to work.
  3. KENDEUCE
    KENDEUCE
    I think Wescott has a blueprint on their website.
    wescottsauto.com
  4. KENDEUCE
    KENDEUCE
    Never mind, the print doesn't show steering box holes!!!!!
  5. el Scotto
    el Scotto
    from Tracy, CA
    Baron that'd be perfect, if I could read the numbers! :D
    Just need them for the steering box holes!
    Super duper thanks!! :)
  6. hightower611
    hightower611
    Will this work?
  7. Baron
    Baron
    Measured my frame this morning and from the center of the front most spreader bar bolt to the center of the hole for the steering is 38 1/2 inches.
  8. el Scotto
    el Scotto
    from Tracy, CA
    Thank you guys so much!! :D
  9. 32fordrat
    32fordrat
    Maybe my math is off and so is my Inch calculator on my iPhone, but these measurements only add up to 38 1/8 inches. I think thats 3/8 of an inch difference. ?????????
  10. terryble
    terryble
    from canada
    I can see the stearing box hole, there is only one, right?
  11. 32fordrat
    32fordrat
    Yes the large one, in the center of the three that are in a triangle around it.
