Technical Other Pitman on F1 Box
Discussion in 'Traditional Hot Rods' started by nosdan, Jan 6, 2014.
  1. nosdan
    nosdan
    Anyone know if a Vega, Corvair, or another pitman arm will fit on an F1 steering box?
  2. ksford
    ksford
    I think cj 5 jeep manual box steering arm will fit length is longer will be good if you have to bend up like pretzel to clear hairpins little on bulky side needs grinder work to look real nice
  3. Andy
    Andy
    The sector shaft in the F1 box is the same as they used in 37-48 p*** boxes. The p*** arms will fit but will be clocked wrong. You would need to cut out the blocking splines so it can be repositioned.
    PS,I have a bunch of them.
  4. nosdan
    nosdan
    Thanks. Yes, I'm having clearance problems with the bent Ford pitman I have and looking to see what my options may be...
  5. thunderbirdesq
    thunderbirdesq
    Lots of options, I had to make one for my T, I think I used the splined top from a 70's F100 and the bottom half of 40's p***enger one. You can also heat and bend them if the angle is the only issue.
