Disguising 305 to look like 283 Help - Harmonic Balancer, Pulleys, etc
Discussion in 'The Hokey Ass Message Board' started by KustomRocket88, Jan 6, 2014.
  1. KustomRocket88
    KustomRocket88
    Hello folks,
    Please don't chew me out with this thread as I've read the semi-popular topic on dressing up a 350 to look like a '57 283 (which is more difficult than the task I am asking). I have a 305 I want to disguise as a '63-65 283. I've heard I'll run into issues when it comes to pulleys possibly, and the short water pump. Could anyone help me out, anyone who has done this conversion? What are all the right parts I'll need to make this happen (as far as I can go without ridiculous lengths)? I'm not sure if the oil dip stick is reversed on the 305 than the 283, but when it comes to that point I don't really care. Basically want to keep the general feel and overall look of an older 283. So far I've got the rams horn exhaust manifolds, and I'm looking into mid '60s 2bbl and 4bbl intakes with the oil fill at the front.
    Thank you!
  2. Gman0046
    Gman0046
    Your wasting your money trying to fool people you don't even know. What's the point? No one out there even cares what engine is in your car.
  3. you can change pulleys , water pump , intake etc.......but the heads will let everyone know it is not a 283
  4. saltflats
    saltflats
    from Missouri
    You will need heads with no bolt holes , short water pump , short water pump pulleys , you can change balancer if you want but not needed.
    You may need to remark your balancer so the timing mark will be in the correct place (some time behind the water pump) the its intake carb dist and so on.
  5. sawbuck
    sawbuck
    from 06492 ct
    I care ..
  6. 49ratfink
    49ratfink
    didn't sound like he wanted to fool anyone, but wants his 305 to have the look of an early motor.... as for nobody cares.. I'd be guessing he is doing it for himself.
    for me the main thing would be the oil fill in the intake and early valve covers, then you need to hide the PCV somewhere.
    if you go with a short pump you would probably (maybe) need to change the balancer as well.
    I'll be making a 305 look vintage for my car as well when I get to that part. gee i sure hope people I don't know are fooled so it is not a waste of money...:rolleyes:
  7. 327Eric
    327Eric
    Oil fill intake, the right valve covers, and exhaust manifolds. Chevy engine orange paint, and the alternator on the drivers side. This will fool 90 percent of the people. The other 10 percent you will never be able to fool, so don't even bother. I'm the kind that looks for the breather on the back of the block to verify, and many others on here will do the same.
    A short water pump and pulleys will work on a late 70's 350, so I dont see why it wouldn't for a 305. I have heard there is a difference in balancers, but never seen it matter.
  8. tfeverfred
    tfeverfred
    If anyone bends over to see if your motors a real 283, kick 'em in the ***. You'll get the subject changed and meet new people.:D
  9. drdoom
    drdoom
    from new jersey
    use steel script valve covers.then use the oil fill tube from 1966 327 vette which the pcv valve attached to. screw bolts into the heads with sealant then cut off the heads and blend.run short waterpump and block mounted brackets and wa la 283
  10. KustomRocket88
    KustomRocket88
    Thank you ratfink, this is helpful. I'll be eager to see how yours turns out as well! Would I have to change the balancer in order for the other pulleys to work correctly (going with the short water pump)? Or would I still be able to have everything line up okay?
  11. KustomRocket88
    KustomRocket88
    Thank you! That's a good idea. Also, would a C4B edelbrock aluminum intake have the pcv valve provision?
  12. KustomRocket88
    KustomRocket88
    Definitely good to know. I wouldn't be surprised, we are after all dealing with Generous Motors
  13. mechanic58
    mechanic58
    Also...if you're going to get technical about it you need to make sure you're using an early style timing chain cover to match the small dia 283 balancer. As far as the PCV goes you can drill a hole in the back of your intake near the distributor area that you can put a PCV grommet in, but you'll also probably need to manufacture some sort of a baffle to go beneath it to keep splashing oil from being ****ed into your intake via the PCV. Earlier small blocks also used different style oil pans. The laymen would probably never notice, but anyone claiming to be a connoisseur of small block chevrolets would. The only obstacle you'll never be able to overcome though is the crankcase breather hole that was cast into the back of all small blocks prior to 1968.
    Edit: The early small block oil pans will fit an early 2-piece rear seal 305 block - 1977 and earlier. I think in '78 they all went to p***enger side dipstick and the early pans won't fit.
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    ...are you serious...it costs the same to build a traditional 283 as it does to build a non traditional 305. This is another "Help me disguise my non-traditional motor I got for free" thread. Just find a real 283...it's not hard. If you don't have the money to buy one, then save till you do.
    kidcampbell71 likes this.
  15. KustomRocket88
    KustomRocket88
    I didn't get the 305 for free, it's in my '85 Caprice I bought a couple years back. Runs very well otherwise :)
  16. the-rodster
    the-rodster
  17. gimpyshotrods
    gimpyshotrods
    I got my 305 for free too.
  18. KustomRocket88
    KustomRocket88
    Rodster, what did you do for a PCV system? By the way I plan on running an Edelbrock Aluminum C4B intake. From the posts I've read thus far, I am going to ***ume it has no provision for PCV and I'll have to drill somewhere to the back of the carb but clear of the runners? It has the oil filler tube at the front. Also what did you use for pulleys? Did the 283 ones work; I also don't want to change the harmonic balancer if I don't have to.
  19. 58 wagon
    58 wagon
    from tucson,az
    Here's my old 305. ( Red one ) I purchased what I thought was a late 80s 1 piece rear main 350 finned pan at a swap meet turned out it was a 305 pan. Never did anything with the 305 other than mock up or a parts holder for my other motors. I could never justify dumping money into it when I had several 283,327,350s that needed the same. But it's as traditional looking as it gets lol 327 Power Pack heads (no holes), offy tunnel ram, offy finned covers and that stupid pan! That I never got to use.
  20. saltflats
    saltflats
    from Missouri
    You need to look at your balancer and see where the timing tab is if its behind the water pump you will have to remark it or you wont be able to set timing.
    as stated you can drill the intake between the carb and dist then I would get one of the lifter valley baffles to control the oil splash in the valley.
  21. KustomRocket88
    KustomRocket88
    Okay, that makes sense. Also, if I drill into the manifold and (how would I make the baffle?), would I also have to use a breather on the front oil fill tube? I've read about people doing this, but I'd rather personally use a fill tube that has a PCV provision like off a Corvette. If I do this, where does that hose connect if the fitting drilled and tapped into the manifold ties into the carburetor?
  22. ned5049
    ned5049
    you see look alike Rocket Olds V8 valve covers on SBC's. Now, who's fooling who?
  23. the-rodster
    the-rodster
    I put the pcv in the back of the drivers side valve cover.
    All of the pulleys are stock 305, long water pump.
    I redrilled a 283 fan to fit the long water pump.
    Rich
  24. gimpyshotrods
    gimpyshotrods
    I used a baffled grommet.
  25. Junior Stock
    Junior Stock
    With a little grinder work,I haven't seen any 305 heads in a while, the heads could be made to look like these. Been told they were on 58's with air ride suspension and later trucks with air brakes.
  26. saltflats
    saltflats
    from Missouri
    Moroso makes a lifter valley baffle part number 25050.
    I think the oil fill tube that has the threaded fitting for the PCV has a screw on cap that will not let the crank case breath. Then you will have to open a hole some were.
  27. KustomRocket88
    KustomRocket88
    That is a good point, but what about the breathers people put on in place of the cap? That way the filtered air is coming in (if I understand this correctly?)
  28. saltflats
    saltflats
    from Missouri
    If the PCV goes to the front breather and you put a vented cap on it you wont get a good working PCV system it will only want to pull air in from the vented cap and not evacuate the crank case as well.
  29. brett4christ
    brett4christ
    Unless I'm grossly mistaken, a PVC-equipped engine is a "closed system", meaning there is no ventilation for the crankcase other than the PVC.
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Chevrolet p***enger cars all got PCV valves in 1963, and still had oil fill tubes with push on breather caps.
