Projects Mounting v8 60 onto a model a frame
Discussion in 'Traditional Hot Rods' started by beffa, Jan 6, 2014.
  1. beffa
    beffa
    What is the best way to mount a Ford Flathead 60 h p engine onto a model a frame ?
  2. 343w
    343w
    I like using the original type V8 biscuit pad type mounts with welded side mounts off the frame rails, or in the front cross member. There are plenty of people here that can provide pictures for you.
  3. Jalopy Joker
    Jalopy Joker
    using a "60" because?
  4. badshifter
    badshifter
    Temporarily.
  5. They used to say it is hard to beat cubic inches. Have you checked the cubic inches for a V8 60?
    Charlie Stephens
  6. Gary in MN
    Gary in MN
    Here is a picture of my front mount. I was able to use the stock shock holes to bolt it in.
    Gary in MN.
  7. StrickV8
    StrickV8
    Temporary wooden mount?
