1932 Ford Roadster Dimensions
Discussion in 'The Hokey Ass Message Board' started by sodas38, Dec 2, 2010.
  1. sodas38
    sodas38
    I know there are dimensions floating around out there, but I came across this drawing and thought it was a very good reference for someone that may need measurements.
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    no ****...:D
    kidcampbell71 likes this.
  3. Blue One
    Blue One
    from Alberta
    Still no good, can't read the numbers on either version of the drawing.
  4. sodas38
    sodas38
    I'll try and post a bigger one tonight, can't get in photobucket here at work.
  5. sodas38
    sodas38
  6. Deuce Daddy Don
    Deuce Daddy Don
    If you want the "real thing" (FOMOCO BLUEPRINTS) PM me your zip code & I'll get back to to for total price. 1932 Ford Roadster body 3 views, all measurments, also 1932 Ford frame (Stock) 2 views all measurements.
    NOT WESCOTTS drawings!
    sko_ford likes this.
  7. henry29
    henry29
    Any 5 window blueprints?
  8. Deuce Daddy Don
    Deuce Daddy Don
    Henry 29----No, but all 5 window parts are the same & interchangable with roadster parts, Fenders,deck lid,etc.-----BUT NEVER a 3wnd coupe!!!
  9. Deuces
    Deuces
    I can read them on the HD wide screen.... :D
  10. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    The Panel below the deck lid does not interchange between a 5W coupe and a Roadster.
    I don't think that the doors are interchangeable either. :)
  11. A Boner
    A Boner
  12. Norman Werner
    Norman Werner
    Powell ****e, OR.
    To: Duce Daddy Don:
    How can I contact you re the duce drawings?
  13. F&J
    F&J
    Norm, Click on his name above in post number 9. As soon as you click, there will be a pop up and you can either choose to send him a PM (private message) or choose to send him an email.
  14. floydjer
    floydjer
    Leg room must be a bit tight with the cabin length being 26 1/8" (lower left):rolleyes:
  15. Mr48chev
    I've got one of Don's Deuce frame blueprints and it's a must have if you are building, planning on building a deuce or if you just want something really cool for wall art. You need a large size wall space if you want to hang it up though.
    I saved the drawing that Sodas38 posted and you can expand it to full screen size with Picasa real easy.
  16. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I wish things were interchangeable.
    -Deck lids are the same
    -Doors are different length with the 5w's being longer which means the rockers are different.
    -The panel above the deck lid is about 2's deep on a 5w where it's 8" on a roadster. The deck lid moves forward on a 5w
    -The panel below is taller on a 5w which is how the deck lid is rotated forward.
    -Quarters are a lot lore different then I originally thought. The flare on a roadster above the wheel is the noticeable difference but also the length from the B Pillar to the wheel well is longer on a roadster due to the shorter length on the doors.
    -The ****pit on a 5w is roomier which is what causes the panel above the deck lid to be so short.
    Lots of little differences but those are the ones that come to mind. I really am starting to learn the differences now that I am putting my 5w together with roadster quarter. Lots of differences but not nearly as much as when you lump the 3 into the mix.
  17. Augustweld
    Augustweld
    from Arizona,
    I will see if I can get the numbers off ===Thank You Augustweld
  18. erniequ
    erniequ
    The fomoco Blueprints 80223
  19. erniequ
    erniequ
    how to I get a hold of you. I hope it you still have a blue print of 1932 ford Roadster body and frame
  20. Mike Goldman
    Mike Goldman
    Did y
    Can you still get a hold of Deuce Daddy Done? Interested in those blueprints. Tried tapping his name and all I saw was start conversation. Sorry I'm a newbie.
  21. DDDenny
    @Deuce Daddy Don
  22. V8-m
    V8-m
    from Alaska
    Do other drawings exists...hood, doors, dash. If yes why we can't have it. Must be laying somewhere in archives..I think so..
  23. V8-m
    V8-m
    from Alaska
    Here a little bit better quality
