Hello everyone. I'm just wondering if the below heater is a stock Ford heater or if it is an aftermarket item. I checked quickly the last time i seen the car and I did not see any names or logos on the piece. It will most likely need some parts to get it back operational again and I'm wondering where I would find them. A quick look online turned up a wide variety of styles, some mentioning them as a Ford accessory and some mentioning that they were aftermarket so I thought I would turn here. Thank you, Thomas
Is this what I'm looking for http://www.secondchancegarage.com/public/photogallery/1940forddluxconv/heater.jpg
I think so...do some searching on Ford Barn V8. You also need a switch that is different from any of the '41-48, and you need to figgerout differences from '39 (the first hot water heater from Ford), which is similar. I think you may also locate drilling templates there. The '41 is identified by the little pull-out knob for defroster ****erflies, which was replaced by a cable up to switch plate after 1941.
I may leave this one in the car. It's installed and works, and has been in there since at least 1957. I may try to locate a 1940 one, but won't empty my pocket book to do so. Thanks for the information.
Thought I would be looking at the rusty remains of an exhaust heater, glad to see you have hot water heater, regardless of make or manufacturer.
Don't know who manufactured the '41 filter in the car, but it is a proper Ford accessory one from 1941. The basic design (with mods as noted) was used '41-48 and came in various colors and stripings to match standard and deluxe cars and different years. Fan is between core and defroster manifold, reversible with 2 speeds in each direction. I rebuilt one for my '48 and nearly went mad figuring out the wiring for that!
I had tried that at first, but did not realize that I had to click the "advanced" ****on to edit the ***le. Thanks
I thought to only difference between 39 & 40 was the door pull color. They can me ran with the 41+ switches, I think they are better than the 39s
As mentioned above, the heater shown is a 41-48 Ford dealer installed accessory item which was very common in the day. Here is the correct heater for a 39/40 Ford. They both work good.
I was able to track down a 39-40 heater complete and at a reasonable price. I like the style of the 39-40 much better. May donate this heater to my Father's Model A build. Thank you everyone for your help. -Thomas
