Model A sedan tire size updated. can you have too much rake?
Discussion in 'The Hokey Ass Message Board' started by rawcjw19, Jan 8, 2014.
  1. rawcjw19
    rawcjw19
    ImageUploadedByH.A.M.B.1389236428.248754.jpg . We mounted our new tires, I know they aren't bias ply but we wanted a better ride.do you think we have too much rake?
  2. aonemarine
    aonemarine
    from Delaware
    It's perfect, don't change a thing.
  3. madmak95
    madmak95
    Ditto!!!
  4. rawcjw19
    rawcjw19
    Thanks ,we like the crazy rake look. Just hoping it didn't look goofy,and cause driving issues. Too bad I had my inner fender wells all patched up,because they rub. Going to have too do a minor tub job.
  5. HOTRODPRIMER
    HOTRODPRIMER
    IMHO,there is no such thing as too much rake!
    and Bias Ply tires ride great. HRP
  6. tfeverfred
    tfeverfred
    Seems a little high in the ***, to me.
  7. 26 T Ford RPU
    26 T Ford RPU
    Just a tad high, looks to have a 70s rake going on imo. JW
  8. Jalopy Joker
    Jalopy Joker
    yep, looks like Cool 70's - might need to modify seat base so that you lean back a little to have a better ride for you.
  9. aonemarine
    aonemarine
    from Delaware
    for the ones that think its too high in the rear, remember cars are like women, when they start getting old the top end falls off and the rear starts to sag. Better to have her a little high and tight to start with LOL
  10. bustedwrench
    bustedwrench
    Looks pretty damn good to me.
  11. oneowner
    oneowner
    How about sizes??
  12. trbomax
    trbomax
    A noticeable rake is nice,but,and just IMO,when it starts to look like a fat girl sat on the cowl,it needs to be evalulated.
  13. rawcjw19
    rawcjw19
    fronts are 145 sr 14 Michelin 24 inches tall, rears are 31x12.5.15 hoosier. I wanted to match the fenderwell as much as possible. It's are first build so it's all pretty new to me.
  14. True big N little tire rake. Looks good.
  15. scrap metal 48
    scrap metal 48
    Looks good to me.. Nice sedan...
  16. jimz31
    jimz31
    from PA
    The rake is perfect!!!
    Nice ride you have there!
  17. 60 Belair
    60 Belair
  18. I like it !
    4* seems to look great on a hotrod.
    The problem I encounter is with 4* rake and the engine sitting at 3* the other way - makes a 7* visual problem at cowl to engine relation.
  19. brandon
    brandon
    takes quarter work and a 32 ch***is to perfect the rake on a tudor....:D
  20. check your caster because changing rake changes your axle inclination/angle
  21. rawcjw19
    rawcjw19
    I would love to have that, but the 32 frame was out of my budget :( I am also struggling with just patch panels and the chop.
    Never thought of the castor, Whats the minumum I can get by with there?
  22. brandon
    brandon
    I shoot for 5 minimum...I , personally, like around 7 degrees
  23. wicarnut
    wicarnut
    "*****in" John
  24. HOTRODPRIMER
    HOTRODPRIMER
    I like the rake,but the wide steamroller tires on the rear does scream the 70's. HRP
  25. I think you can have to much, but yours is not one of those. It's perfect, I'd leave it just like it is. I struggled with getting it right on mine and it looks like we have about the same rake and similar size ( diameter ) tires. The only difference is visual difference with the fenders on mine. IMO.
    I read 31 Vickys reply and thought wow. so I just put my magnetic angle finder on the air cleaner and it reads 1 degree down in the front, when I set up the drive train I used the 3 degrees down (trans) 3 degrees up (rear end) formula with the frame level to the floor, so I must be at 4 degrees rake with the tires on. I guess the bottom line is, how does it look when it's sitting and yours looks good.
  26. ROADSTER1927
    ROADSTER1927
    HRP and I agree on that! Gary:)
  27. cody1958
    cody1958
    from wichita ks
  28. TudorTumor
    TudorTumor
    I think it looks great!
    If I filled my wheelwells like that I would have too much. When the previous owner of mine filled the roof he extended it over the windshield replacing the Visor with it. Aids in vision. I also added a Prism on the dash to see the traffic lights.
    Just Tubbed the rear. Going wider but not taller and loosing the Mags. ImageUploadedByH.A.M.B.1389281575.798055.jpg
  29. 340HilbornDuster
    340HilbornDuster
    Love it! & The Team III wheels are Killer!
    & yeah, check the Caster...
    What's wrong with the 70's?...(except maybe the paint jobs?)
    T
  30. Boones
    Boones
    from Kent, Wa
    little to much rake for my taste. it has a nasty look to it with the rake and blower
