I need a banjo fitting to fit the 18mm O-ring inlet on a power rack. Fittings that say they're for power steering applications are not readily available locally, but I found one that is intended for the cooling line on a turbo intercooler. Any problem using the intercooler banjo for power steering? Too much pressure for it?? Looks like this:
You mean like these? http://www.unisteer.com/power-steering-pumps-accessories/18mm-banjo-fitting.html Seriously, any decent steel AN/JIC fitting should comfortably handle power steering pressures (600-1600psi depending on your pump/application) but you need real hydraulic hose and fittings, not steel-braided AN.
Yep- But the Unisteer fitting is not available locally, but the pictured type is. I didn't know if it was literally the same, or built to a different (ie lower pressure) spec.
Try the guys at Earls Indy. They have a website, but that is only a portion of the stuff they carry. great to deal with and fast.
