Projects Plan II - 62 Chevy II Drag Car
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 27, 2013.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I realize that. It's a drag link just the same weather it has an idler and tie rods or it just connects from the pitman to the opposing side at the steering arm. It's the idea of making one that work's for you.
    chryslerfan55 and els like this.
  2. squirrel
    Sort of...but not quite. with a drag link, if there's a bend in it to clear something, it may or may not clear as the link can rotate. With an idler and center link, the idler keeps the center link from rotating.
    1Nimrod, chryslerfan55 and els like this.
  3. Heo2
    Heo2
    No doubt having the tube straight like that give most stiffnes
    but its better to have a bend in that tube if you crash
    it helps to soften the inpact and work a bit like a crumplezone
  4. 1964countrysedan
    1964countrysedan
    from Texas
    I have nothing to add at this point other than I think this body style rules as a street/strip machine.
    Thanks for taking the time to post.
    1Nimrod and els like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Even a jump hope can't rotate with out help. So don't help it, combat it. It's all in the engineering.
  6. squirrel
    Yup....and one of these days I'll get some parts in the mail, and figure out how to make it work, one way or another. I did find a longer tie rod end to use at the pitman arm end, which will let me put a bend in it. But I don't like that solution.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Understood :)
    els likes this.
  8. squirrel
    I got some drag link parts in the mail, did a little ***embly and measuring, looks like the link is probably going to clear the notch in the oil pan OK. Won't know for sure till the car is put together more....I need to put the "real" engine in it for that, which will be a little while till it happens.
    I got my rearend, which was hiding under my 57 suburban....getting ready to tack perches on it, and see how it fits. 57 ford wagon, with aftermarket axles with chevy bolt pattern, and Chevy 11 x 2" drum brakes. I'll swipe the 3.25 locker out of the 55 to go in this rear. Final gear ratio selection will happen when I get the car to the strip.
  9. enloe
    enloe
    from east , tn.
    Cool, keep on keeping on
  10. mt94ss
    mt94ss
    Can you set the engine back a bit to help with steering clearance and weight distribution?
    els likes this.
  11. squirrel
    The engine is set back as far as it can go without whacking the firewall, which I don't want to do. And I"m moving the rear end forward 9" to seriously alter the weight distribution.
  12. squirrel
    Did a little cutting today.
  13. mt94ss
    mt94ss
    Just a little, huh? Looks pretty serious.
  14. squirrel
    The piece that came out will go back in. In a slightly different position.
  15. 1971BB427
    1971BB427
    from Oregon
    Looks like preparation for an altered wheelbase Nova! Very nice!
  16. Model A John
    Model A John
    from wichita ks
    I like what you're doing. Reminds me of what I was cutting up on my Chevy II a few years ago.
  17. Gasser 57
    Gasser 57
    from New Jersey
    This is gonna be ******** man.
    els likes this.
  18. squirrel
    cleaning up the floor before installing it in it's new position. Nice original primer under the crud.
  19. Olderchild
    Olderchild
    from Ohio
    Beautiful, if that was a Ohio car the picture would be of a shovel full of rust
    vtx1800 and els like this.
  20. Boones
    Boones
    from Kent, Wa
    you moving the rear forwards?
    els likes this.
  21. s55mercury66
    s55mercury66
    from SW Wyoming
    As a Buckeye native, you shore got that right!
  22. squirrel
    Yessir.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Or, I've seen the ******* on the floor and now she's in the shower ;).
  24. mgtstumpy
    mgtstumpy
    Love the build, here's how to do a 64 Fairlane to help others visualize what is happening.
  25. squirrel
    There are lots of ways to do this job, we're doing it kind of strangely to deal with the rust and collision damage on the car. It was destined for the s**** heap....in AZ, this car is a real piece of ****.
    Almost ready to put the floor back in. Got some bodywork done on the quarters, cleaned up the floor section, trimmed more excess stuff from around the trunk area.
    Also got some parts in the mail, including the roll cage and seats.
  26. AHotRod
    AHotRod
    Cooool Seat Mount :) That should p*** tech.... :)
    els likes this.
  27. powrshftr
    powrshftr
    What are those seats you went with?They look great!
    I've been looking at the Limeworks seats,and their diamond tuck pattern looks pretty good.Im eager to see what you have in mind for covers.
    Scott
  28. squirrel
    The seats are from Speedway, they're called "sportsman seats" or something. 5 lbs each. They are more square looking than the 1960s buckets, but they'll work ok. They sell square tuft seat covers, I'd like to do diamond tuft.
  29. powrshftr
    powrshftr
    They look pretty close to old seats.Lots closer than a shiny aluminum high back Kirkey seat for sure....
    Nice job so far.That car is gonna be a really big deal when the dust settles.
    Scott
  30. squirrel
    Thanks! I just hope it goes fast
