Projects 61 Ford unibody build
Discussion in 'The Hokey Ass Message Board' started by JakeDW, Nov 10, 2012.
  1. luckystiff
    luckystiff
    thats kinda where i've been floating. with the narrower explorer rear on top of there was already a good bit of space back there with the stock 9" i know theres a good chunk of realestate to fill back there. i missed a pretty decent pair of old cragars that were 15x8.5 with 4" of backspace.
    my mock up last week with a coupla rollers last week showed me a tire size change for the rear was in order. i had planned to run 215/70/15 all around, the rollers i had to stick under it have 235/75/15 on them and they sure do fill the wheel openings nicely....ken....
  2. pro-street uni-body
    pro-street uni-body
    from las vegas
  3. pro-street uni-body
    pro-street uni-body
    from las vegas
  4. willo_96
    willo_96
    Just read through all so far, lookin good, nice work
  5. JakeDW
    JakeDW
    from Missouri
    Really like that color.
    Jake
  6. JakeDW
    JakeDW
    from Missouri
    Thank you
    Jake
  7. JakeDW
    JakeDW
    from Missouri
    Yea I had to go by inches 26 was the number I did not want to be taller than that so 205 70 15 was what I went with.I did not want to make the Z any taller and the notch any bigger so that was the number.
    Jake
  8. pro-street uni-body
    pro-street uni-body
    from las vegas
    Here are some pics these are 31×18.5 ×15 huge and tucked and rides nice 1389652858591.jpg
  9. pro-street uni-body
    pro-street uni-body
    from las vegas
    You are putting the mustang 2 I used a 87 dodge diplomat on my uni-body with torsion bar and it works great
  10. JakeDW
    JakeDW
    from Missouri
    Finally did some work on the truck got the rest of the rust on the p***enger side taken care of.Now on to the drivers side back seat mount then I can make the trans tunnel.
    Jake
  11. pro-street uni-body
    pro-street uni-body
    from las vegas
    Nice job that looks great I need to do a little of that my self
  12. pro-street uni-body
    pro-street uni-body
    from las vegas
    Any body looking to buy a truck mine is for sale 702 427-2413
  13. truckrod
    truckrod
    from akron,ohio
    pro-street unibody, I like your truck !
  14. pro-street uni-body
    pro-street uni-body
    from las vegas
    Hey thanks I like your truck also you are running a 460? I have a transmission for a 460 that was a spare for the trophy truck we have but were selling truck my partner died and motor is in machine shop they are saying 8,000 to fix the pistons which are.250 thousants over I think hes trippin need to go see him my self I guess but If you need trans it is fully built race trans
  15. 65gregg
    65gregg
    from Willis, TX
    I'm joining the party late, great build!!!!
  16. pro-street uni-body
    pro-street uni-body
    from las vegas
    Right on welcome
  17. Landmule
    Landmule
    I love these unibody trucks and I'm enjoying your build - nice work!
  18. JakeDW
    JakeDW
    from Missouri
    Thank you.
  19. JakeDW
    JakeDW
    from Missouri
    Thanks.
  20. JakeDW
    JakeDW
    from Missouri
    I have been putting off making a trans tunnel because of this a tall trans bolt in cover (finally got one off evilbay)its gona make this way easy I cut the hole for the Lokar shifter and stuck it on now I can go back and cut all the extra under it off and just leave a flange to bolt it to good thing kept everything I cut out because some of it has to go back in.
    Jake
  21. JakeDW
    JakeDW
    from Missouri
    I allso stuck the front clip back on for motivation.And I have never seen this truck with a motor in.Made me feel all warm inside to open the hood to a motor.Went to a few machine shops around town to see what I was in for with the rebuild machine work.
  22. JakeDW
    JakeDW
    from Missouri
    I also pick up a core support as the one on the truck is way beyond being fixable it was so rusted this one is really solid only one 2 in spot I need to fix.
    Jake
  23. JakeDW
    JakeDW
    from Missouri
    So got the trans hole cut out and some 1/4 in round bar welded around the hole.
    Jake
  24. JakeDW
    JakeDW
    from Missouri
    Parts welded in that I cut out months ago wish I would have had this tunnel back then.and round bar welded around the inside and just a bit of clean up grinding.
    Jake
  25. JakeDW
    JakeDW
    from Missouri
    Removable tunnel on needs a lot of clean up and that will get done when I get the cab floor stripped at a later date lol.
    Jake
  26. luckystiff
    luckystiff
    whats the story on the removable tunnel? Big truck application?
  27. JakeDW
    JakeDW
    from Missouri
    I am not real sure think they will fit 61-66 most I see have the 4x4 shifter hole on the side allso my guess would be for the auto and 4x4 trucks.
    Jake
  28. Ford blue blood
    Ford blue blood
    My 73 F100 with a 4 speed had a removable tunnel. Looked a lot like yours.
  29. Anything with a factory floor shift lever of some sort got the removable tunnel. The covers are pretty much the same shape all the way into the 80s; I used one out of a later F150 truck with the non-rail cast iron toploader OD and it bolted in to a '67 with zero mods. Been a long time, but I'm pretty sure these will fit all the way back to '61.
  30. JakeDW
    JakeDW
    from Missouri
    Guess I was not even close lol.Its hard to believe that 61 to early 80s floor is the same or close enough to inter change these tunnels but cool if that is true.i have the motor way up in this thing so it won't hit the ground when down I felt I was lucky that I dd not have to mod it any its close but should be good with the C4.
    Jake
