What makes a '33 ford vicky special? what are the differences in that compared to a standard '33 ford?? just looking fo a little insight, might be purchasiing a '33 sedan.
Vickies have a forward slanting back panel, and tudors' back panel slants backward. A '33 Vicky has a bit of a hump at the beltline and '34's are basically flat all the way down. A '33 Vicky uses a gas tank cover, but a '34 has no separate gas tank cover.
I believe the 34 and last "vicky" of the 30's was the only one available with an actual rear trunk, opened from the inside near the rear window frame.
