Technical latches for top hood on '32 Ford coupe
Discussion in 'Traditional Hot Rods' started by deuce666, Jan 13, 2014.
  1. deuce666
    deuce666
    from Oregon
    I decided to run only the top portion of a hood on my '32 3W coupe. The body and hood are steel, the hood is a Rootlieb (spelling?), and I'm trying to figure out a traditional solution - something that might be correct for the early to mid '60s.
    I searched around quite a bit but didn't find anything very useful.
    I've seen Dzus fastenters used. Any other clever ideas / suggestions?
    By the way, I don't particularly like the leather straps that connect the top hood to the frame. No offense to those who do :)
    Any and all suggestions would be greatly appreciated!!
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    We used welding rod in the hood side loops of the tops bent to fit across 3 loops. Shaped like a horseshoe with long lugs at the open end. 2 near the back and two up front with a rightly sized bungee cord between them, holds tight, doesn't rattle and easily removed.
  3. big duece
    big duece
    from kansas
  4. gasheat
    gasheat
    from Dallas
    Two bungee cords running side to side have worked for me for over 15 years. Cheap, easy and you have to get on your knees and look up to see them.
  5. verde742
    verde742
    I remember a few year back Roy Brizio used velcro, said hood didn't come off at over 80 mph..
  6. HOTRODPRIMER
    HOTRODPRIMER
    A good friend of mine use to use a bungee cord between the two hood halves but now uses a screed door spring stretched between the two top halves. HRP
  7. MAD 034
    MAD 034
    from Washington
    My dad has used bungee cords on his deuce roadster hood top since 1988 with no problems.
  8. sko_ford
    sko_ford
    On wowcars' dads 32 chevy they made a slide pin with a cotterpin to hold it. Kind like a door or gate blot
  9. gearheadbill
    gearheadbill
    Me too. Just did a hood top-only project. Works great.
  10. deuce666
    deuce666
    from Oregon
    you guys (and gals) are awesome!!
    Just what I needed -- but I probably need more training when using "search" to find those old threads!!
    Thanks again,
    Richard
  11. HomemadeHardtop57
    HomemadeHardtop57
    Can someone post a pic of how the bungees are attached.
  12. mgtstumpy
    mgtstumpy
    What about these, can't recall who sells them. Are they traditional?
  13. X38
    X38
    Limeworks.
  14. 325w
    325w
    I was lazy and hooked the bungee in the hood hinge loops. Stretched right to left one front one back. Worked.
