Technical 389 in a 55 Pontiac?
Discussion in 'Traditional Hot Rods' started by Toast, Jan 1, 2014.
  1. Toast
    Toast
    from Jenks, OK
    I know the blocks are all supposed to be the same but how much changing is required to put a 389 and later trans in a 55 Pontiac where a 287 auto was?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Well, if you can find a '59 or '60 389, it's almost a bolt in. What "later trans" are you talking about? Makes a difference.
  3. Toast
    Toast
    from Jenks, OK
    Probably be an early 60's motor and trans. Or a th400
  4. bobwop
    bobwop
    from Arley, AL
    sounds like a lot of work to me
  5. 42merc
    42merc
    In the mid 60's I put a '60 389 engine in a '56 sedan, using the '56 trans, an absolute bolt in.
  6. plymouth1952
    plymouth1952
    its so close a bolt in is all you can say !
  7. Toast
    Toast
    from Jenks, OK
    Isn't the 287 front mount and 389 side? also I have heard the oil pans are enough different on some to cause issues?
  8. Don't forget that big car Pontiacs until '65 model year (exception being 64 Tempest and GTO) used a transmission mounted starter. You can use a later block with 61 thru 64 transmissions (I put a 69 Ram Air 3 in a 64 Grand Prix with the slim jim trans) but I'm not sure on earlier ones.
    To use a TH400 you need a adapter plate to mount the starter to the bellhousing. I found a plan online a long time ago for making it but I can't remember who had it posted.
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The front cover and mount can be used on the '59-'60 engines.
  10. Toast
    Toast
    from Jenks, OK
    The 389 I am looking at is mid 60's as stated earlier. Looking for someone that has done that swap?
  11. swe64
    swe64
    i have a post here where i put a 400(pontiac) 67 engine in my 1958 gmc truck(370 block and 4speed gmc auto)
    new engine needed a 1960 timing cover and i made a adapter plate to fit 700r4 chevy trans.using same mid engine/trans mount and a new rear trans mount.mid mount is welded to adapter plate.
    ken sweden
  12. Toast
    Toast
    from Jenks, OK
    Thanks but not really what I need for info.
  13. The 55 timing cover on the later motor should mnt the front easily. The problem is with the later trans. If you use a conventional x-member towards the rear of that later trans you now have both eng & trans mounted in the middle with no side support. It'll rock all over the place. I think fabbing side mnts for the later motor's gonna be a lot easier than trying to duplicate factory side mnting for the later trans. Short answer-not a bolt-in
  14. 73RR
    73RR
    Have you read through the multiple Pontiac-specific forums that exist?
  15. Poncho60
    Poncho60
    from N Illinois
    Check the Performance Years (PY) website ...forums. If you can't find help there then I don't know where you will find it...it's an all Pontiac site!
  16. Toast
    Toast
    from Jenks, OK
    Thanks guys I will check the Pontiac Forums
  17. Toast
    Toast
    from Jenks, OK
    Thanks, I just talked to a machine shop in town here that has a completely redone 56 317 that the customer never picked up. They are expensive, but I think I can get it at a fair price, he will let me know Friday. Rebuild on the current 287 is in the $4K to $5k range depending on what can be saved in the valve parts. Parts are available but 1 year only makes them expensive.
  18. Keep your poker face. If you don't buy that 317, he'll probly end up married to it. LOL. That said, he almost needs you more than you need him. Especially if he got some "front" $$$ from the customer
  19. Mr48chev
    Swapping the front covers on those is real simple and a guy wants to check the timing gear on any Pontiac V8 that isn't fresh anyhow.
  20. Toast
    Toast
    from Jenks, OK
    Yep I have already made him aware that I might be his only buyer ever. I think I can make a pretty good deal on it. Plus the 317 would be a nice upgrade from the 287.
  21. 55chieftain
    55chieftain
    The early "reverse cooling" 55-59 covers I don't believe would work on a later engine. I did use a 60 cover which still can use the 55-58 front mount set up on a 66 389 to help mount it in my 55.
  22. andy checchia
    andy checchia
    from USA
    Hi, Before you plunk down any hard cash, look at the pontiac custom safari web site. The key to putting a later 389 into that 56 is getting a 60 389 front cover. It's cast iron an it will be compatable with the later model (61 up) cooling system. Try to go with a later (post 60 engine) you will have a lot more transmission options.
