For all you y block fans
Discussion in 'The Hokey Ass Message Board' started by 1954fordkustom, Dec 21, 2013.
  1. RPMhotrod
    RPMhotrod
    from Philly, PA
    Thanks! They have made the wish list!
  2. OahuEli
    OahuEli
    from Hawaii
    Thanks guys! I've never built a project around a particular part before, but maybe I oughta buy a set of these cool valve covers and and start from there. I do know of a guy who has a '57 F100 less the bed and a possible lead on a 292 & 3 speed...hmmmm.:D
    The .060 over 292 that was the original propulsion for my avatar sounded really good with headers and gl*** packs and I think I'd rather build another Y block than the 429 currently on my engine stand.
    My next thought , is there a valley cover in the works Brandon?
  3. roosterslucky
    roosterslucky
    from florida
  4. 1954fordkustom
    1954fordkustom
    Eli thanks for taking the time and doing this. They look great painted as well. I am working on doing a valley cover. I have bounced around a few ideas. So far I'm thinking about doing a valley pan with the fins running the same way. I'm contemplating on doing 1 with or without the oil fill tube in it. Maybe you guys can give some feed back on what you would like to see available.
    Thanks Brandon
  5. salf100
    salf100
    I say go with the filler tube. I'm buying the whole set :) Great work!
    From my teletype.
  6. 56 ford custom
    56 ford custom
    from Socal
    There are a few things I need made for a few Y blocks I need and I will take you or ship the original parts that I need copied. Can I put an order in now for a pair of these valve covers along with a matching valley pan with filler tube and pcv valve baffle?
  7. OahuEli
    OahuEli
    from Hawaii
    You're quite welcome, your idea has great potential. Also, it looks like others would like to see a valley pan with oil filler tube too. I'm thinking you can't go wrong here.
  8. 1954fordkustom
    1954fordkustom
    Thanks I'm working on doing a finned pan with filler tube. I just haven't made up my mind on what design to go with.
  9. daily_driver
    daily_driver
    Subscribed. Defiantly like the different look of them. A valley pan would look great too. I second the filler tube and pcv valve baffle and hole in the back. Keep us posted!-dd
  10. 1954fordkustom
    1954fordkustom
    56 ford shoot me a pm
  11. El Hueso
    El Hueso
  12. 56 ford custom
    56 ford custom
    from Socal
    Woupd a text be quicker? Haha
  13. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
    Are these available now?
  14. Its mid-Feb now. Update on availability?
  15. EnragedHawk
    EnragedHawk
    from Waco, TX
    I know I'm a bit late to the party, but those are totally bad ***!
  16. y'sguy
    y'sguy
    from Tulsa, OK
    I endorse! looks like a good alternative!
    BTW if you build a vallycover I would consider using a threaded oil fill tube. That way you can remove it and ship it in a smaller box. a few bucks saved, I think.
    Might cost you more in setup though.
  17. fryguy
    fryguy
    These are way cool. Almost one of the items that makes you want to build a car around. The finished polished pics really makes these pop.
    Fryguy
  18. lowXM
    lowXM
    holy **** these are sick! will they fit a 272?
  19. I don't think so. They should fit all the other Y-blocks, though. The 272 is kind of an orphan.
  20. ynottayblock
    ynottayblock
    Todd I think youre thinking about the 239 inch y-block. The 272, 292, and 312 should be the same.
  21. Malcolm
    Malcolm
    from Nebraska
    Doesn't the 239 use the same valve covers as the 272/292/312?
  22. I was actually just being a wise-***.:D:rolleyes:
    Though numerous other differences between the Ford & Lincoln, I'm pretty sure the valve covers interchange whether it's a Ford, Merc, or even a Lincoln (if the right studs are used).
    Sent VIA top secret BIGREDTODD Mobile HQ
  23. Jakes38
    Jakes38
    I know for a fact they will fit a 272. We popped the ratty old covers off the mill in my 55 Customline. Even with all the grime and cobwebs and whatever else, they really REALLY look killer. Pics don't do them justice!
  24. lowXM
    lowXM
  25. 1954fordkustom
    1954fordkustom
    Hey guys I just saw your guys post. Here is an update I was told I would have them by the end of this month. I'm still pushing to have them by then. If for some reason it changes I will update you all. Just be patient with me I will have them up for sale as soon as I get them
  26. lowXM
    lowXM
    Is it possible for you to find out how much postage would be to Brisbane Australia?
  27. 1954fordkustom
    1954fordkustom
    Ok guys valve covers are on their way. I should have them early next week. Very stoked to finally get these
  28. 1954fordkustom
    1954fordkustom
    Y block valve cover now available. $310 a set plus shipping. Please me if interested. I do have a few raw sets without polish available as well for $290 plus shipping
    ImageUploadedByH.A.M.B.1401609791.273022.jpg ImageUploadedByH.A.M.B.1401609812.928838.jpg ImageUploadedByH.A.M.B.1401609826.733253.jpg ImageUploadedByH.A.M.B.1401609847.316786.jpg
  29. OahuEli
    OahuEli
    from Hawaii
    Nice! Lets bump this back up so people will see 'em and maybe buy too.
