Technical Aussie 1929 Chevrolet Model A RPU
Discussion in 'Traditional Hot Rods' started by Richie R, Jan 17, 2014.
  1. Yes a Chevrolet Model A RPU, have a chev 29 ch***is, a 57 Stovebolt 235 with Powerslide (just sold that heavy ****er), a truck manual bell housing with T5
    Going for a 50s highboy look of a basic Ford RPU but with exposed chevy parallel springs. Using a 49 F1 front axle with matching Dana 41.
    Puting together a 28 A bone cab for it out of others s**** parts. All Aussie RHD stuff so far.
    Been looking for online diagrams on building a cab subfloor, does anyone here know a link to one?
    I can get a Australian manufactured subfloor in standard or 6" extra at $475 Orrrrrr,,,can get side panels made up easy enough in any length to match my floor.
    Custom or commercial subfloor ***y? Help me decide.
  2. Phil Stevens
    Phil Stevens
    here's the measurements for Model A RPU if it helps
  3. Why bother using a Chev ch***is? And the parallel leaf spring thing? I don't get why?
    Wouldn't it be a **** ton easier to buy an original frame.. box it, and use Ford parts instead? It'd look way better and the stuff just bolts together. Why make it so complicated?
  4. iarodder
    iarodder
    I guess I'm confused is it a Chevy or a Ford? Kinda says both.:confused:
  5. midroad
    midroad
    I can tell you from experience you will have trouble getting the front suspension low enough. Even if the axle is dropped there will be no space for steering components to go across. I ended up using a very non Hamb stainless IFS to get my '29 Chev tourer sitting right.
  6. You can use a 50's Chevrolet truck front axle to give you some drop.
  7. Well I have started to mock up everything, the ch***is I picked up is actually a 1927 as it has the shorter wheelbase, the 29 I was planing to get has damage.
    Looks like it will now be a 3 springer, will swap my F1 spindles and brakes onto a later 30s Ford axle and run split bones. Yes the F1 parallel springs just look wrong and are 2 inches too wide to fit without spreading the front rails.
    As for why a chev ch***is,,,I just like the look of them, are a heavier gauge metal and have a high rear kick up.
    This ch***is is in perfect condition, can see all the factory stamps (like a "S")
    Going to move one of the factory cross members back and that will pinch the ch***is nicely for the A body.
    Just now need a A front X member.
    The 27 has almost a identical wheelbase as a A bone too.
  8. Forgot to say, this thing is a true budget build. All the cowl ***y bits, doors, chev tank, ch***is, F1 front and rear, the 235 only owe me $800 in total, and have sold my power slide for $100.
    I have traveled the State looking to pick up all the parts.
    A good solid model A ch***is in this country can cost $1000.
  9. Blackroad
    Blackroad
    from Sydney
    ImageUploadedByH.A.M.B.1390105985.959819.jpg ImageUploadedByH.A.M.B.1390106011.585965.jpg ImageUploadedByH.A.M.B.1390106029.302411.jpg ImageUploadedByH.A.M.B.1390106055.502373.jpg . Here is my 14 year old sons 30 Model a pickup which is being built on a Dodge ch***is. Use the dodge ch***is as cheaper than model A and has a natural 5 inch kick up at back. Fitted model a front and rear crossmembers and reshaped the front of frame to resemble model A.
  10. I paid $750 for my Model A ch***is and it came with a full front end and some other bits i sold off. Was worth it though, everything just bolts to it. Can't get any simpler.
  11. Nice job on the frame end, will have to copy it. Other than the different front spring hanger, your dodge ch***is looks almost identically to my chevy.
  12. Blackroad
    Blackroad
    from Sydney
    Couple more photos of frame end to show how we cut it. No new metal needed. ImageUploadedByH.A.M.B.1390218808.568602.jpg ImageUploadedByH.A.M.B.1390218822.068002.jpg ImageUploadedByH.A.M.B.1390218836.201648.jpg
  13. I really like where you are going with this- 3 springers are great!
  14. I think so too, wish more would run rear parallel rear springs. I love the simple mechanical connection between the ch***is and axle, been used from the horse and cart days and still used on nearly every pickup and larger truck today.
    Most think the shackles look ugly but the way the rear tapers down on the early Chev to the cast end look as good as it gets with parallel rears.
    For a budget build like mine there is no better way.
  15. 1928arat
    1928arat
    from australia
    Has any more been done on your car I'm heading down this road with the ch***is
  16. George Miller
    George Miller
    from NC usa
    Way to go, it is much more fun to do your own thing. Any one can do it the same as every one else. To me a hot rod should be part of you, not a copy cat car.
    Outback and grumpy32 like this.
  17. x2 :)
  18. hellerlj
    hellerlj
    from Minnesota
    I paid only $750.00 for a complete, Running, 1929 Ford Tourer, had a new top, drove it home from near Traralgon to Sale.............OH YA !!! That was 1974.....seems prices have changed a bit !!!!!!!!!!!
  19. Bronsonkills
    Bronsonkills
    Can you post more photo's of your build , heading in the same direction on 1929 Chevrolet, but having a hard time finding body parts in the states ...live in California Ford country not my Chevy roadsters out this way
  20. wbrw32
    wbrw32
    Bronson,,,,you might check the date on a thread when you post on it,,,this one is over two years old
  21. Outback
    Outback
    from NE Vic, Oz
    Richie had this on the market, not sure if it sold, there was also another build thread too....
