Fordomatic shifting too high
Discussion in 'The Hokey Ass Message Board' started by deome, Jan 17, 2014.
  1. deome
    deome
    Hello guys !!
    I rebuilt a fordomatic 2-speed for a friend and the ****** shift 1 to 2 very very high (55Mph).
    The transmission had the same problem before the rebuilding.
    My Friend use Dexron II transmission Fluid.
    Any idea to solve the problem ?
    Thanks !
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. 47 PLY
    47 PLY
    from UK
    I had the same problem with a fmx box and it was just the vacuum ***ist unit that had failed.Cheap to fix.I don't know if your box has one of these but if it has check it out.
  4. The Fordomatic has a manual linkage that controls both upshift & downshift. I dont think there was a vacuum modulator until the early C4. Try taking a little pressure out of that linkage from the carb to the ******.
    When it's too tight, the ****** is getting a signal that the accelerator is depressed more than it is, extending the shift point. When it's too loose the ****** will shift too soon, and possibly slip. Somewhere in the middle will behave behave like you want.
    Sent VIA top secret BIGREDTODD Mobile HQ
  5. deome
    deome
    thank you for your reply guys :)
    The ******'s got a vacuum modulator, I replaced it
    I gonna check the throttle linkage
    if you have other idea ... :confused:
  6. 56 ford custom
    56 ford custom
    from Socal
    If it has a vacuum modulator then its a later trans maybe an fmx.
  7. sunbeam
    sunbeam
    Ford o matic went to vacuum throttle control late in 1961 & 62 -63
  8. Mike51Merc
    Mike51Merc
    Do you know the modulator is adjustable?
  9. 57Custom300
    57Custom300
    from Arizona
    Some of the later model modulators had an adjustable screw inside the fitting where the vacuum hose plugged in to it. You could adjust in in or out to adjust the shift point. People installed them thinking they could just make a little adjustment to fix their car when by that point they had more problems than that. Plus a lot of times the screw ended up on the floor.
    Ford did make different length rods that fit into the modulator to adjust the shift point. Did the same job as the adjustable modulator. Shorter pin, shorter shift I think is how it went. Then there the guys that lose the pin and it won't shift at all.
  10. deome
    deome
    ok, thank you very much
    I will check that
  11. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    You should also use ATF for a ford.
