Projects What's involved with filling the roof on a model a sedan?
Discussion in 'The Hokey Ass Message Board' started by willbierfarms, Nov 27, 2013.
  1. willbierfarms
    willbierfarms
    from palmyra mo
    I'm thinking hard about filling the roof on this model a I bought. Is there a good aftermarket kit for this project? What's involved with doing this and are there any tricks I need to know
  2. Noland
    Noland
    there are many threads on this. Alot of people use skins from other cars or vans. It involves welding and taking your time.
  3. charlieb66
    charlieb66
    You must go slow with the welding. Unless you are an accomplished welder with sheet metal you should not try it, the top may wind up FUBAR.
  4. txturbo
    txturbo
    its not that difficult if you gas weld it and hammer the welds as you go along.
  5. phoenix5x
    phoenix5x
    from Ohio
    Go to a junk yard find a nice Chevy van or a station wagon with some nice beads in it...I used like a 90's 18 person van roof cut it off with a sawzall then flipped the back of it to the front of the sedan and just cut the excess off gave some nice beads in the roof
  6. That's so follow the crowd like 70's-80's stuff. What's wrong with the new way,,, a soft insert? It's much easier than you think. It's also CHEEP, and it doesn't require Bondo.
    The Wizzard
  7. Mo rust
    Mo rust
    I made several cross bars with some crown in the middle for my 30 sedan and the used a flat peice of 20 gauge and worked it out from the center moving back. All the donor roofs that I could find had ribs in them which is a look that I don't care for.
  8. nickleone
    nickleone
    Look at AMC Eagle wagons. Also if there is a van conversion shop in your area where they put raised roofs on full size vans you may get a roof cut off for free.
    Nick
  9. mike bowling
    mike bowling
    I'm with Phoenix5x on going with a van roof for a filler. I like the way the ribs break up the span, and used a late 80's Chevy conversion van roof with ribs that were up,not indented.If you cut the roof off and flip it around (front to back) the curve on the back of the sedan fits really well.I also ended up with about 4 ft. of extra roof material, and cut the ends of the ribs off that and welded them to the front of the new sedan roof to blend it all in over the visor. Send me an e-mail address, and I'll send you pictures (anyone who's interested).I dragged my feet about chopping and filling, but what a difference! 3" chop. Good luck! Mike from M***. :cool:
  10. HOTRODPRIMER
    HOTRODPRIMER
    I am from the school of thought that the original soft tops are correct in appearance and are as traditional as the day is long.
    It's not that hard to do and IMHO the filled,ribbed tops remind me of the 80's slick look,,but that's just me. HRP
  11. I should have also said if you can drive a Tack hammer and read a tape measure you can do a stock type insert at home yourself.
    The Wizzard
  12. That's what I think too. I just don't think it's worth the work.
    Post some pic's if you do it...
  13. willbierfarms
    willbierfarms
    from palmyra mo
    See I like it both ways. The cloth top looks great but so does a we done filled roof I'm not down with the ribs tho it has a Boyd, little jon look while they built great stuff I'm not a billet guy. I don't have the gas welding skill to do it but I can swing a tack hammer like a tweaker on a three day buzz
    ALLDONE likes this.
  14. rawcjw19
    rawcjw19
    I found a 72 suburban, I am hoping to get the roof off it. Think it would work?
  15. Blue One
    Blue One
    from Alberta
    I'm with the guys who like the soft top look and I'm also with the guys who like a steel roof filled top.
    Advantages of the soft top:
    It looks like the car was built originally, cl***y and traditional.
    Advantages to the steel filled top:
    It makes the body stroger structurally by a huge amount and provides a low maintenance leak free roof.
    What I would do would be a combination of both.
    Strong, good looking and traditional in appearance as well. Not to mention a little sneaky ;)
    How ?
    Instead of putting in the usual wood and chicken wire that the soft top usually uses, install some metal ribs as supports and then weld roof metal into the top opening leaving the original recess for the tack strip that finishes the soft top insert.
    After that you can have the top covered with soft insert fabric and install the tack strip.
    The results:
    A structurally solid and leak free roof with the traditional old soft top look. :)
    A win win in my eyes.
    QcATudor likes this.
  16. Just Gary
    Just Gary
  17. rawcjw19
    rawcjw19
    Thanks Gary, I already followed your chop thread :)
  18. woodiewagon46
    woodiewagon46
    from New York
    If you can get a copy of Hot Rod Deluxe magazine, July 2013, Roy Fjasted from West Coast Street Rods, welds an insert in a Deuce sedan. If you can't find it PM me and I'll send it to you. Model A and Deuce are very close in dimensions.
  19. scrap metal 48
    scrap metal 48
    I too would run some sort of soft top...
  20. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I must have misread it. I thought he asked how to do it, not how everyone else would build HIS car :rolleyes:
  21. willbierfarms
    willbierfarms
    from palmyra mo
    I have decided to put an insert in it and cover it with cloth
  22. Kirk Hanning
    Kirk Hanning
    That's an excellent choice! You won't regret it!
  23. willbierfarms
    willbierfarms
    from palmyra mo
    I want to on the inside make a louverd panel out of aluminum and have it striped
  24. Deuced Up!
    Deuced Up!
    I vote with the "soft top" crowd here. I have no issues with mine. It has been through several heavy rains on the road and survived 120 mph p***es at the H.A.M.B. Drags. [​IMG]
  25. WB69
    WB69
    from Kansas
    I did the same as did Mo Rust. It came out good. Then put a fake soft top on it.
  26. Kirk Hanning
    Kirk Hanning
    I vote for an aluminum louvered insert also. Then again I may be a bit partial.
  27. Blue One
    Blue One
    from Alberta
    I guess you also missed the purpose of a discussion forum, to get info and share ideas. Lots of info provided and some alternate ways to approach something never hurts.
  28. rawcjw19
    rawcjw19
    ImageUploadedByH.A.M.B.1400548880.349730.jpg ImageUploadedByH.A.M.B.1400548902.401502.jpg
    Does this look ok for those of you that have done it? It is just setting on there, still have to start welding.
  29. rawcjw19
    rawcjw19
    ImageUploadedByH.A.M.B.1400549094.119315.jpg ImageUploadedByH.A.M.B.1400549125.375149.jpg
