Lowering a 64 Falcon, how'd ya do it?
Discussion in 'The Hokey Ass Message Board' started by lrs30, Nov 28, 2013.
  1. lrs30
    lrs30
    from Kentucky
    What method is the best, what method is the cheapest, or did you bag it? All questions I have. I will continue to use the search function also, but would like to hear from those who have done it, and maybe a pic or 2 of the finished process.... thanks
  2. CHEAP!!! blocks in back, cut springs in front,,,:D
  3. Billy
    Billy
    I agree with S**** Iron... I cut about a coil and a half and installed 1" block in the rear of my daily driver. Drives great. Very affordable way to do it.
  4. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Blocks in back, cut coils and 13''-5 lug wheels up front.
  5. gimpyshotrods
    gimpyshotrods
    560in-lb. 65-66 Mustang springs in the front, 1 coil removed (for now). Custom 6-leaf springs from ESPO, 2" less arch.
    Cheapest? Cut coils and blocks. 3" is the max for practicality, and even then, you might not be able to fill the trunk, or use the back seat. 2", if it is a real driver.
  6. ffr1222k
    ffr1222k
    I would do the Shelby drop in front. Blocks in rear.
  7. gimpyshotrods
    gimpyshotrods
    Yes to the Shelby drop, but that does NOT lower the car by much more than 0.40". The Shelby drop relocates the upper control arm to change the camber curve during suspension cycling. It is the single best, cheapest performance handling suspension upgrade for cars with this ch***is, but not a lowering technique. Costs one drill bit.
  8. lrs30
    lrs30
    from Kentucky
    Ok I'll bite, what's a Shelby drop? And what is the advantage?
  9. gimpyshotrods
    gimpyshotrods
  10. lrs30
    lrs30
    from Kentucky
    Awesome info, thanks for the info!
  11. HOTRODPRIMER
    HOTRODPRIMER
    Mine sat pretty low but it still had the small factory wheels. HRP
  12. Tomkat39
    Tomkat39
    My 60 Comet after 1 1/2 coils cut , no blocks, in back but with 74 Maverick rear 8 inch, 14 " wheels
      270.4 KB
  13. jjjmm56
    jjjmm56
    from FL.
  14. Billy
    Billy
    The black 64 is my daily, and the green 60 is my wife's. I have a coil and a half off the front and 1" blocks in the rear on both of them..
  15. ditchdigger
    ditchdigger
    from Eugene,OR
    This was 2 coils cut up front and 2" blocks out back
  16. Billy
    Billy
    Ditchdiger, love your crew cab!
  17. NeonGodzilla
    NeonGodzilla
    Mine isn't a 64 but I cut 1 1/2 coils in the front & 3" blocks in the back. 185/65/14 ft tires 225/70/14 rr tires.
    Revernd Paul
  18. Billy
    Billy
    Pics, please...
  19. wbarber13
    wbarber13
    Depends on budget.... Cheap is cut and block. If funds aren't a problem the correct way is to call Detroit springs and have them make some to your car for the height that you want.
    http://www.eatondetroitspring.com/
    They made front and rear for my fairlane with 3" front and 2" rear drop, ride great.
  20. NeonGodzilla
    NeonGodzilla
    It's my avatar, here's another
    Revernd Paul
  21. NeonGodzilla
    NeonGodzilla
    Apparently my phone doesn't wanna play nice. I'll try again later
    Revernd Paul
  22. stickerdick
    stickerdick
    I'm looking for the best way to lower a 64 wagon that will have 17" rims, going to do the 5 lug conversion, will run the 6cyl / automatic for now, but I am thinking the disc brake conversion up fron, but need to figure out how to convert rear drums to 5 lug.
  23. gimpyshotrods
    gimpyshotrods
    You would be best off replacing the entire rear axle, especially if any more power is in the future.. The 6-cylinder Falcon's came with a dainty rear axle.
    There are also access holes in the axle flange face, which disallow re-drilling the pattern.
  24. Ivko
    Ivko
    from Austria
    hy, i cut the springs for 1 coil and want to do now the shelby drtop on my 62 comet. are any further modifications required?
    thanks
