Projects F100 To chop or not to chop that is the question!
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Jan 17, 2014.
  1. tlmartin84
    tlmartin84
    from WV
    Well the time has come. Time to either chop this thing down, or weld it up and move on. Problem is I can't decide. Rational side says leave it alone, the wanna be cool side says CHOP it!
    The metal work and getting the windshield to fit doesn't worry me. My main concerns down the road are things like the headliner and rear upholstery. As of now you can buy those pieces straight off the shelf, If I go modifying this, I will have to do custom. SHOULD I LET THAT STOP ME??
    Since I have transplanted a top, the additional metal work will be minimal, mainly just sectioning the roof.....
    Here are some pictures of FRANKENSTEIN....
    What do you guys think???
  2. johnod
    johnod
    Always liked those trucks, if it were mine I don't think I'd chop it.
  3. 46chevy
    46chevy
    from reeds,mo
    Chop it!!!!!!!!!!!!!!!!!!
  4. john mullen
    john mullen
    they look cool as built ..No Chop
  5. junkman8888
    junkman8888
    Greetings! You might as well chop it as the cab and doors are cut up anyway, but as always, have the windshield cut first, then cut the cab to fit the gl***.
  6. Rob68
    Rob68
    I say no. To me the look right with the factory hight. I've seen a few chopped and it doesn't look right.
  7. Frank32
    Frank32
  8. nashster
    nashster
    from Pgh
    I agree with John. I would leave it stock. I do like certain cars and trucks chopped but these trucks just look out of proportion with the roof down.
  9. Geargoyle Curtis
    Geargoyle Curtis
    I agree.
  10. Flathead Johnny
    Flathead Johnny
    from MA
    please don't, i have a 56 F100.....I think trucks look funny chopped......leave it for the cars
  11. Billy
    Billy
    Times 3. It's not the work,it's the end result. They look killer the way Ford did them.
  12. JUNK ROD
    JUNK ROD
  13. banginona40
    banginona40
    I wouldn't chop it. Everything else gets put out of proportion when you do. Ford did good on that one when the designed it. JMHOP
  14. second fiddle
    second fiddle
  15. blowby
    blowby
    from Nicasio Ca
  16. rusty1
    rusty1
    lower the truck, not the top.
  17. Jalopy Joker
    Jalopy Joker
    **x2
  18. SOCALRICK
    SOCALRICK
    from SO. CAL
    Leave it as is. Cl***ic look. Chop a car when you finish the f100!
  19. Landmule
    Landmule
    I agree - chops on 56 F-100's can mess up the proportions.
  20. v8juice
    v8juice
  21. tiredford
    tiredford
    from Mo.
    I have seen people do this on the FTE site and the gl*** is a nightmare to make right. I would not do it.
  22. Imperial66
    Imperial66
    from NC
    IMHO, they are to fat and curvy for a chop. It makes them look squished.
  23. 56don
    56don
    A 56 f100 is a perfect chop project. They look a lot better chopped, more proportional. It is like a T Model coupe, it just needs to have a lower lid.
    Take a couple off the top...
  24. willymakeit
    willymakeit
    Ok What are going to do,now that you have asked?
  25. OneBad56
    OneBad56
    I have yet to see one that is chopped and looks right. Most take too much out and the proportions are all off. If you were going to chop it, the most I would take out is an inch to an inch and half and that's a lot of work for a small amount.
    One chop that looked good was to only take the front pillars down a bit to bring the front top down to a better horizontal line or plane to make it the same as the rear.
    Now if you want to get rid of that "jockey" cap look, pancake the top and shave the drip rails. At the same time to keep everything in proportion, pie cut the hood, more in front than the back.
    Another trick I've seen done is to channel the front of the cab 1.5 inches by tipping it forward but that leads to a whole lot of other modifications to pull it off.
  26. Tacson
    Tacson
    Dont Chop. If it was a slant cab I would say yes but not a 56'. No real noticeable gain by chopping.
  27. L. Eckart
    L. Eckart
    Be careful on that windshield. I know a fellow who bought three new ones before he got one that made it through the cut to the gl*** without breaking and it was supposedly done by a gl*** pro.
  28. Ralphies54
    Ralphies54
    Im going to say no even tho my 54 is chopped 5 inches. 56s look too good with the wrap around gl*** to mess with them. If you do decide to cut be aware that the gl*** is s nightmare. And if you have the talent to do the chop then don't let the headliner be the deciding factor, that will be a piece of cake compared to all else. Ralphie
  29. 55willys
    55willys
    Chop it! Then section it to get the proportions right. 1''- 2'' chop and 2 1/2''- 4'' section. And while you are at it etc. etc. etc. it never stops!
  30. Mr48chev
    Yep, that is the only way to do one of those right. There used to be a 56 Effie floating around this area that was chopped that changed hands at least once a year because no one could get gl*** to fit or work in it due to the way it was chopped.
    I like chopped trucks obviously the a 56 Effie is the one truck I would never chop.
