Features Who's Building a T?
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 19, 2011.
  1. hudspeth
    hudspeth
    from Arkansas
    Thanks, are you referring to the height of the rail from top to bottom, or from the ground to the the bottom of rail?
  2. sport fury
    sport fury
    just the vertical dimension of the rail
  3. hudspeth
    hudspeth
    from Arkansas
    Taking a shot in the dark here, but would guess around 5".
  4. chuckles0
    chuckles0
    >Wow ! This Thread has gone on a long time! >> A lot of nice Ts'.. Well ,, Here's mine. Still building. Will do a Build thread soon. what I started with.12/2012.and now,12/2013. Built from 8 different T cars and parts!
    All Ford drive-train.
    .Nothing newer than '55.. I think I have the 'Stance I was after. A lot to do yet!
    >I don't know how to get a larger pic?
    12/2012.
    and now,12/2013. All Ford drive-train.
    http://www.jalopyjournal.com/forum/picture.php?pictureid=497817&albumid=42703&dl=1387331951&thumb=1
  5. scott49mercury
    scott49mercury
    here is mine, this is a good thread
  6. hudspeth
    hudspeth
    from Arkansas
    ImageUploadedByH.A.M.B.1388202910.573216.jpg ImageUploadedByH.A.M.B.1388202922.789937.jpg
    Finishing up the floor board...
  7. Chuckles, tough to see in the picture, did you weld the roof/window corners to the main lower body or is it still bolted on as 26 / 27's came? is that a 26 / 27 type?
  8. Ragtop
    Ragtop
    No computer expert here but I think if you save your pics to a website like PhotoBucket, you can add the link to your post and it'll usually come out bigger - neat project! Lots od work putting all those parts together.
  9. ChuckUFarley
    ChuckUFarley
    from Around
    With all of those "T"s s***ched together, you should name your car Franken-T. ;):D
  10. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Not something I built, but looked interesting enough to share.
  11. jhexide
    jhexide
    23 t project a bought
  12. ThomasT
    ThomasT
    What engine is that jhexide in the photo?:confused:
  13. Baron
    Baron
    Looks like a 250 -292 six cylinder Chevy .
  14. jhexide
    jhexide
    230 inline chevy 6
  15. chuckles0
    chuckles0
    welded . It's a '25 T.Drs.cpe.
  16. chuckles0
    chuckles0
    CAM01605.jpg welded couple more pics. '25 T ..
  17. Tim_with_a_T
    Tim_with_a_T
    I guess I haven't posted on this one yet. Here's my heap of trouble:
  18. AndersF
    AndersF
    I have finally started on mine.
    Just got my frame but it need some modification to fit.:D
    Put some of the major stuff together so i could do some mesurements.
    And then i could do a blueprint to follow.
    Hard to see in the picture but it is on the wheel.
    Im decide for a kind of model A style frame.
    A z in front and rear and spring over front axel.
    Made a simple jig to make the rails equal.
    My father have this in his backyard i could use as a weldingtable for my frame.
    Cut a long V in the frontrails to taper them.
    And then start the welding.
    Then some final adjustment before tacking things together.
    Some final welding.
    And finally i got two framerails.
    Lil'Alb likes this.
  19. ThomasT
    ThomasT
    Looking real good so far.
  20. Slimegreeeeeen
    Slimegreeeeeen
    Got those same seats as you, Chuckles Zero. They were bar chairs when I found them in Littleton, CO. Dead ringers.
  21. Bre42
    Bre42
    from Australia
    ImageUploadedByH.A.M.B.1392099323.671103.jpg I have just got my T body. Will be doing a build thread when I get a chance hopefully in the next few weeks.
  22. chuckles0
    chuckles0
    >Yep !Bar stools from a closed down bar from the 60s".. "Free'!!
  23. only just found this post,
    Im building a Tall T too, its a 26/27 running and driving now but not finished, still needs paint its just quickly spray bombed to protect it from the elements :) not decided on colour yet, but not going black! excuse the bad photos
    [​IMG][/URL]
    [​IMG][/URL]
    I just started a build thread the other day
    Charlie
  24. Some great stuff being built, I just started a build thread in my 22 tub
  25. hudspeth
    hudspeth
    from Arkansas
  26. hudspeth
    hudspeth
    from Arkansas
  27. Slimegreeeeeen
    Slimegreeeeeen
    Exciting news for the Austin hot rodding community. Mecury Charlie's old Tall T, --the one he famously built in thirty days and drove to Paso Robles many moons ago -- has returned home.
    Out of respect to the new owner, we won't name names. But don't be surprised if you see a *****in Tall T buzzing around town. Plans are to put it back to as close as what Charlie built as humanly possible (like the pic). This is a big win for Austin. Be on the lookout, Austinites!
  28. Slimegreeeeeen
    Slimegreeeeeen
    The Von Franco flames and the wheels are different. It had some bodywork issues repaired. The lavendar glitter vinyl has faded on the seats. Other than that, it's the same.
  29. ottos
    ottos
    building a tall T . Big cubes, 4 speed and quick change rear.
  30. BigMikeC
    BigMikeC
    24' Coupe. I'm building mine for top end. About 40mph.
