Projects 1956 Ford "Canned Monster" Gasser
Discussion in 'The Hokey Ass Message Board' started by Lancer, Jan 5, 2014.
  1. Lancer
    Lancer
    57Custom300 thats great to hear. Can't wait to get this one put together and DRIVE it.
  2. Dan Timberlake
    Dan Timberlake
    Didn't realize Y blocks head bolts are so nice and far away from the bores. I think that is a nice detail for a little better ring seal without use of deck plates, although honing with deck plates is always recommended.
  3. That is definitly one of many good qualities of the Y-Block. Although I do hone with deck plates on my race engines they do not distort like the sbc does.
  4. Doing some balance work on the crank today. ;)
  5. Lancer
    Lancer
    Few pics of the balancing going on today with the crank. Dialing it in. Tim can explain more in detail.
      240.9 KB
      205.5 KB
      211.6 KB
  6. Crashhead
    Crashhead
  7. Roothawg
    Roothawg
    Tim does know his way around a Y block.
  8. Crashhead
    Crashhead
    Diggin that engine already...im sure it'll sound sweet!!
  9. Not much to explain, or too much to explain if you really want to know. I will say this though, most engines I balance that are from the '50s or '60s
    are pretty close to begin with (of course there is some adjustment for aftermarket pistons) but all in all the big three did a fairly good job back then. '70s, not so much. :rolleyes:
  10. mechanic58
    mechanic58
    mctim64 - I could listen to you row through the gears with your y-block all day long. I love the sound it makes.
  11. OahuEli
    OahuEli
    from Hawaii
    Love the sound of that Y-block! Tim I remember when you first posted this video, I think I watched it 5 or 6 times in a row. lol Btw, what ever happened to that motor?
  12. Redlighting
    Redlighting
    from Tn
  13. It's sitting in the shop, I'll use it for something one day although it has a bit too high compression for pump gas. Might end up in the dragster someday. Never know. :rolleyes:
  14. crminal
    crminal
    Tim mentioned this build to me the other day. Very nice! Will follow along.
  15. Lancer
    Lancer
    Since I'm new to these Y-Blocks I could use some suggestions for transmission set ups. The car will be manual and runs at very high RPMs. I have a Lakewood ****ter shield for a Chevy. Is there anything like that for a Y-Block? Should I adapt the Lakewood housing to the Y-Block and use a Muncie or Borg Warner trans?? That also leaves the flywheels and starter to deal with as well. What are your thoughts?
  16. OahuEli
    OahuEli
    from Hawaii
    Have you checked out Y-Blocksforever.com? I've no doubt Mr. Mummert can help you out. He's the "Go To" guy for these old motors.
    As for your high rpms, are you going to add anything to the bottom end to help out? I know the block shrouds the crank and mains, just wondering if you're going to use a girdle etc.
  17. yblocker
    yblocker
    from Layton Ut
    4 speed top loader ! Rug input shaft, should be able to hold up.
    idtoy likes this.
  18. Lancer
    Lancer
    Rug input shaft. Please explain. Also what about a ****ter shield?
  19. yblocker
    yblocker
    from Layton Ut
    Lancer,
    Rugs are the FE version of the top loader. They featured a larger diameter input shaft the"nub on the end is shorter. Doesn't require machining to fit into the pilot bearing.
    The HEH (what I have) is from a 302 with a ten inch clutch disk.
    The FE is an eleven inch.the heh is narrower in diameter but is an eighth of an inch too long. ( I simply used the angle grinder) another other mod I had to do was the collar on the snout of the transmission had to be turned down to fit in the y block p***enger bellhousing. used the stock mechanical linkage, (which was kinda a ***** to track down.) And works good.so fat I have mocked it all up and have yet to find a Trans. mount
    Hope someone can chime in on this one. Try google search on David kee top loaders
    the bolt pattern is usually spot on to the p***enger bells.
    great build very inspirational.
    Troy
  20. PandorasBox99
    PandorasBox99
    Im watching this show good stuff to come I can smell it in the Air
  21. Lancer
    Lancer
    We've finally named the car, "Canned Monster"
  22. luke13
    luke13
    ha har harrrr... i remember that episode of loony tunes,
  23. Lancer
    Lancer
    On the stand, ready to start ***embly soon.
  24. Quick time offers a Bell/****ter shield but I've heard of guys having nothing but problems. We just made our own out of 1/4" steel, two piece wrapped around a stock bell.
    No need for a girdle, bottom end is pretty strong in a Y-Block. we will use ARP studs though.
  25. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    brilliant!!!!:d
  26. Lancer
    Lancer
    I'll need your help making one of those up.
    Here is some concept art for the build.
  27. Lancer
    Lancer
    Another progress pic as we work out the design. I'm looking for some color ideas for the car. Right now I'm thinking cream for the main body color and some flake gold for an accent color. Shoot me some ideas.
  28. ottoman
    ottoman
    from Wisconsin
    Man those Jahns sure are vintage 60's pieces! Been a long time since I have seen that technology in a race piston. Now days we would have gone with a longer rod to move the pin up while lightening the piston at the same time and gone with a metric ring pack to reduce the drag but for your g***er they are exactly what you want... and the price was right ;-)
  29. Lancer
    Lancer
    Agree 100%
  30. OahuEli
    OahuEli
    from Hawaii
    If you have a good side or angled perspective photo of the car with the front clip on I'm sure I can put something together using Photoshop.
